rod bolts, do i need to replace them |
Jul 2, 2009 - 8:56 PM |
Enthusiast Joined Mar 10, '08 From Ct Currently Offline Reputation: 0 (0%) |
i brought my rods to my machine shop to have reconditioned, i gave him a call to see where the progress on them where. he had told me that the rod bolts would need to be replaced because they are T-T-Y. but i am having trouble finding them. do i really need to get news ones? does anyone know where to get them?
Jul 2, 2009 - 9:48 PM |
if they are TTY then yes, check the torque spec, if its a lb/ft and then turn 90deg or some degrees then they need to be replaced.
Jul 3, 2009 - 1:54 PM |
Enthusiast Joined Apr 27, '09 From West Coast Canada Currently Offline Reputation: 0 (0%) |
if they are TTY then yes, check the torque spec, if its a lb/ft and then turn 90deg or some degrees then they need to be replaced. Always replace hardware like that when u start ripping things apart! The more you can do while the block is apart the better for future, and most of it is not expensive at ALL |
Jul 3, 2009 - 2:36 PM |
what is TTY
Jul 3, 2009 - 6:06 PM |
Enthusiast Joined Sep 19, '08 From Michigan Currently Offline Reputation: 4 (75%) |
Jul 3, 2009 - 6:59 PM |
Why don't you just order a set of ARP rod bolts? Im sure the pricing on them is the same as dealer prices which are an arm and a leg.
Jul 5, 2009 - 2:06 PM |
i would but i cant find them on the ARP catalog, only the 3sgte and other toyota motors, just not the 2.2.
Jul 6, 2009 - 9:59 AM |
just get new OEM bolts. ARP does not make a 5S replacement rod bolt i went through this about 6 months ago when i rebuilt my 5S. just get new OEM ones you will be fine.
Jul 6, 2009 - 10:18 AM |
who would i call. just a local toyota dealership?
Jul 6, 2009 - 2:48 PM |
Lo-Fi Version | Time is now: December 1st, 2024 - 2:29 PM |
