> replacing vavle cover gasket!? need help, where to put sealant!?
post Jul 3, 2009 - 10:15 PM
mgnt232
Joined Mar 16, '09
(I have a 1994 celica ST 1.8L 7AFE)
i have replaced my valve cover before, but had access to alldata. i remember finding a diagram of where to put the extra sealant to ensure no oil will leak out (it was only in a few spots, i assume where the engine oil was most likely to leak from).
but i do not have the diagram any more and would like to take my valve cover off, to paint. can any one tell me where to put the sealant? thanks
This post has been edited by mgnt232: Jul 3, 2009 - 10:17 PM
- 6GC for Life -
>Semper Fi<
1994 Cupra :p 3sgte
1995 Celica ST DD
1969 Chevelle SS
alllll balls. P2 approved!
post Jul 4, 2009 - 12:01 AM
xrav22
Joined Jul 24, '08
From Canoga Park CA.
after you take off the valve cover just take the new gasket and a little handfull of gasket seal and rub it all over then put the gasket in. As long as you cover the whole gasket you should be good to go.
I am assuming you have 2.2 celica 1.8 may be the same.
post Jul 4, 2009 - 2:27 AM
Mstoochn
Joined Apr 27, '09
From West Coast Canada
QUOTE (xrav22 @ Jul 4, 2009 - 12:01 AM) *
NO, DO NOT DO WHAT HE SAID!!! AHHHH
FIGP goes on the corners of each side of the cam housing
the picture is a GT 5s-fe, the 7a-fe has the same principal, any SHARP corner requires proper sealage
The problem with putting it everywhere is your rubber gasket will harden over time and that sealant will stick to it leaving small holes for oil to drip out of insted of lettting the gasket soak the oil to prevent that. a corner cannot properly be sealed unless the gasket is 100% to the same degree of the cam housing.
This post has been edited by Mstoochn: Jul 4, 2009 - 2:32 AM
post Jul 4, 2009 - 8:55 AM
Nial
Joined Aug 25, '08
From England
QUOTE (Mstoochn @ Jul 4, 2009 - 3:27 AM) *
Definately agree here....if everything is clean and torqued down correctly you shouldnt need to use any gasket sealant at all with a new gasket, maybe a little in the sharp corners to help things along a bit. The last thing you want is bits of sealant breaking off into the oil ways and potentially blocking one, gasket sealant should be used as sparingly as possible where ever it is being used. Personally I dont use any at all and have had no problems with oil leaks yet.
My Facebook GT4 Build page.
https://www.facebook.com/groups/GT4Rebuild
post Jul 4, 2009 - 1:08 PM
Mstoochn
Joined Apr 27, '09
QUOTE (Nial @ Jul 4, 2009 - 9:55 AM) *
the ideal thing is a dime size blob on each corner, front and back of cam housing on the left and right side. THATS IT!
Do not splurg ur valve cover/head.
post Jul 4, 2009 - 5:25 PM
trdproven
Joined Aug 2, '05
From Guam
at the half moons.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Jul 16, 2009 - 11:48 AM
mgnt232
Joined Mar 16, '09
QUOTE (Mstoochn @ Jul 4, 2009 - 1:08 PM) *
when taking off the valve cover and gasket, do you think that the old FIGP (only been there for a couple months) will still be visible as to where it had been?
QUOTE (Mstoochn @ Jul 4, 2009 - 2:27 AM) *
- 6GC for Life -
>Semper Fi<
1994 Cupra :p 3sgte
1995 Celica ST DD
1969 Chevelle SS
post Jul 16, 2009 - 12:03 PM
most of the time, yes. there will be some residue left behind when you pull the valve cover.
post Jul 16, 2009 - 1:59 PM
Malek
Joined Jan 26, '09
From Los Angeles
QUOTE (presure2 @ Jul 16, 2009 - 1:03 PM) *
When I changed mine..the previous owner didn't use figp sealer. instead he used some other non engine sealer so when i pulled it off after finding out it leaked. Chunks of the old sealer fell in. I spent about 3 hours using doctor tweasers pulling chunks of some orange greenish brown sealer.
And a side note, in the chilton and haynes manual it says to use drops of figp at the half moons AND the corners..so 8 points all together. I decided to try it..It hasn't leaked since i changed it in january or february..
post Jul 16, 2009 - 5:22 PM
i trust the toyota manual over a haynes or chiltons any day.
the BGB calls for FIPG only in the hump corners.
Lo-Fi Version Time is now: February 24th, 2025 - 2:09 AM
