> Hmm my 5s is pure monster!!!!!, damage report inside....
post Jul 4, 2009 - 1:10 AM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
Soo..........had a trans problem
and here is the culprit
everything checks out okay here
old and new
the new oem grade parts
new fork, bearing clip, and shifter selector arms
Herosblade (my cousin) out with the old and in with the new
this was a great job to do. was a big pain but well worth the laughs. we had a good time
post Jul 4, 2009 - 1:19 AM
Rusty
Joined Nov 5, '07
From New Zealand
is it up and running yet?
what was your first reaction when you you pulled that out?
So she's back up and running? Great.
post Jul 4, 2009 - 2:04 AM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
yeah she's running but i have a bigger problem now. i cant get into second while driving. everything checks out fine, all other gears work. clutch pedal is still krispy kreme soft frown.gif but im able to get into gear. second is soo mushy soft that i dont know the difference between staying in neutral or if it actually went in 2nd and when i drop the clutch the car doesnt jerk like normal and i hit the gas and the car just revvs kindasad.gif
post Jul 4, 2009 - 7:30 AM
holy crap man.
do you drive with your foot on the clutch pedal?
sounds like the system isnt blead very well.
mightyvac FTW.
post Jul 4, 2009 - 9:25 AM
bseaman_5
Joined Apr 6, '08
From Overland Park
You MFer!!!! quit playing with my emotions!! I'm glad you got it all goin!
post Jul 4, 2009 - 10:10 AM
give it 3 -4 weeks, it will get hard. It happened to me..
post Jul 4, 2009 - 10:22 AM
stetsonaw
Joined Aug 3, '07
From Bellevue, Nebraska
i know your pain (except my clutch pads were gone on the disk and wearing down the rivets). just keep bleeding the clutch man, i had to do mine a LOT since i didn't gravity bleed it. I still need to bleed it more frown.gif 3rd was bein a butt today.
~Andy
Check out my Droid Goodies
| My Flickr
post Jul 4, 2009 - 3:10 PM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
QUOTE (presure2 @ Jul 4, 2009 - 2:30 AM) *
holy crap man.
mightyvac FTW.
haha i dont drive with my left foot down
QUOTE (bseaman_5 @ Jul 4, 2009 - 4:25 AM) *
Brady got a kid that wants it. need to fix this problem though
post Jul 4, 2009 - 3:14 PM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
QUOTE (stetsonaw @ Jul 4, 2009 - 5:22 AM) *
well it seems like 2nd isnt going all the way in frown.gif if i dont press the clutch and try to put into 2nd it doesnt grind right away, only when the stick looks like its in the gate is when is starts to grind a little like your just entering the gate mad.gif
oh yeah.......clutch pedal spontaneously pulls itself down confused.gif faulty new master????
yeah i need to gravity bleed mines too. its hard trying to have the bleeding nipple drip every 5 seconds and then coming up here to forums and going back down to check the fluid level Hahaha
QUOTE (njccmd2002 @ Jul 4, 2009 - 5:10 AM) *
Wow the erection takes that long frown.gif booo well hopefully it does.
post Jul 4, 2009 - 5:19 PM
trdproven
Joined Aug 2, '05
From Guam
I never heard about waiting that long. It should be good at the time you do it.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Jul 4, 2009 - 5:30 PM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
yeah it should be good immediately... are you guys bleeding the clutch right??? its really not tough... two people makes it easier but it can be done with one...
loosen bleeder at slave... push pedal to floor, tighten bleeder - pull pedal up.... repeat 4-5 times.... check fluid level - refill... repeat previous process , after refill this time - with bleeder closed - pump pedal about 15-20 times.... then release bleeder again... push to floor, tighten, pull up... pump 15-20 times.... release bleeder, to floor, tighten, up... pump... refill level.... done... should be good to go forever if you have no leaks
and just to explain the process.... when you push the pedal down... the air is pushed forward out the bleeder.... when you pull it up... its sucks fluid into the line to replace the air you pushed out.... pumping it compresses the fluid and builds firmness to the pedal...
caution: do it somewhere where you can get the floor wet... you will be shooting clutch fluid all over the place smile.gif
Breaking Axles...
post Jul 4, 2009 - 7:16 PM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
yeah my dad and i was doing that. sometimes the pedal pulls itself down. got new slave and master, you think the master is faulty?? like when we open the bleeder and push the like the 3rd time we do that the pedal pulls itself down. then we close and i have to pull it up and pump.
laugh.gif still tripping that the pressure plate came out like that.
post Jul 4, 2009 - 8:15 PM
you should try doing a clutch pedal adjustment. if the clutch grabs right off the floor, than that could fix it.
post Jul 4, 2009 - 8:20 PM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
QUOTE (lagos @ Jul 4, 2009 - 3:15 PM) *
post Jul 4, 2009 - 9:57 PM
netrata
Joined Feb 16, '06
From Maui, Hawaii
Hey Jon, when the car is off try pumping the clutch pedal till it gets firm. If it does then start the car and press the clutch pedal again, and this time if it's spongy or drops back down with no firmness then yeah you might have a defective master cylinder. Too bad I can't fly up cause i'd definitely help you get that car up and running in no time thumbsup.gif
This post has been edited by netrata: Jul 5, 2009 - 3:39 AM
post Jul 4, 2009 - 10:13 PM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
QUOTE (netrata @ Jul 4, 2009 - 4:57 PM) *
Hey Jon, when the car is off trying pumping the clutch pedal till it gets firm. If it does then start the car and press the clutch pedal again, and this time if it's spongy or drops back down with no firmness then yeah you might have a defective master cylinder. Too bad I can't fly up cause i'd definitely help you get that car up and running in no time thumbsup.gif
k shoots nolan. mahalos everyone thumbsup.gif looking for a s54 trans (newer not beat up one Haha)
so what you think nolan?? you gon rep hawaii in the calendar??
This post has been edited by 808celica: Jul 4, 2009 - 10:13 PM
post Jul 5, 2009 - 1:58 AM
Rusty
Joined Nov 5, '07
From New Zealand
did you take the slave cylinder off? or did you undo the clutch line when you took the greabox out and leave the slave cylinder on the gearbox?
how are you bleeding your clutch?
i think the shifter selector arms are adjustable, so align them to how they were orginally.
post Jul 5, 2009 - 2:35 AM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
QUOTE (Rusty @ Jul 4, 2009 - 8:58 PM) *
slave and lines where off the trans hanging by a wire to the radiator hose.
how im bleeding the clutch???....
like what everyone's saying; open bleeder, push pedal, close bleeder. and when there is no pedal pressure i have to pump the pedal then repeat.
selector arms and all stuff were replaces and installed the same.
This post has been edited by 808celica: Jul 5, 2009 - 2:35 AM
post Jul 5, 2009 - 8:41 AM
pump the pedal, hold it to the floor.
have someone watch the slave.
if it stays out, untill you lose pedal pressure, the master is faulty.
if the slave goes out, but starts retracting soon after, the slave is bad.
but, if you never opened the line (since you removed the slave, you shouldnt have had to) you shouldnt even have had to bleed it.
and seriously, buy a mightyvac. you can get it at autozone for ~20-30$, without a doubt one of the best investments i've ever got for the garage. makes bleeding clutch lines, brakes, ect a one man job. (not to mention its much faster than the old pump and hold method.)
10 User(s) are reading this topic (10 Guests and 0 Anonymous Users)
Lo-Fi Version Time is now: January 10th, 2025 - 5:37 PM
