![]() Enthusiast ![]() Joined Jul 7, '09 From Philadelphia, PA Currently Offline Reputation: 0 (0%) ![]() |
hello everybody at 6GC im Bdub. my car is 90 celica gts with a motor out of a wrecked 95 vert (sad). i just gotten this motor rebuilt and bored and i've noticed since i put it all back together that it sounds like a diesel when its cold. it goes away when its warm so its not the bottom end. maybe a valve out of adjustment?
-------------------- 90 Toyota Celica (S53) totaled R.I.P
98 Toyota Corolla (C59) 183k 117whp needs a tune 93 Lexus ES300 (E53) 120k Its a stick 95 Lexus Sc300 AutoTragic FTL |
Enthusiast ![]() Joined Feb 18, '07 From Calgary, Alberta Currently Offline Reputation: 0 (0%) ![]() |
i have the same problem with my fresh motor too. only way to check is to take the valve cover off with a 32mm socket (or huge wrench) and check the clearances. the shims are expensive haha
my mechanic did do the clearances when we put every thing together. i can live with it just as long as it doesnt screw up my motor in the long run.
Enthusiast ![]() ![]() ![]() Joined Apr 27, '09 From West Coast Canada Currently Offline Reputation: 0 (0%) ![]() |
S series engines make alot of nosie especialy with cold oil, its valve tick and loud injectors, its not an issue thats just how they run!
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 8, '03 From Lancaster CA Currently Offline Reputation: 6 (100%) ![]() |
definatly double check your valve clearances. when i rebuilt my 5S it was just as loud. i was sure my valves were in spec, but once i checks some ov them were .020 loose. thats alot! im going to pull the engine when i get teh car painted so ill fix it then.
i got around to making a video y'all can be the judge if its normal or not. ignore the Ram in the beginning of the video
![]() -------------------- 90 Toyota Celica (S53) totaled R.I.P
Lo-Fi Version | Time is now: February 24th, 2025 - 11:13 PM |
