Engine locked? Timing belt? Hellp...!, Car makes the sound like its starting but it doesn't actually turn |
Jul 9, 2009 - 1:41 PM |
Enthusiast Joined Jul 31, '08 From Lansing Currently Offline Reputation: 0 (0%) |
I drove my mother's 1990 Celica ST to my doctor's appointment without any issues. I stopped to get gas on the way and still made it there without any problems. After an hour, I jumped in and started it and and pulled up to the road to make a turn. Just as I got ready to turn the car stalled out. I went to start it back up and it just wouldn't do it. I tried a few more times to start it but no luck. The battery is fine, the alternator is new.
I moved the car out of the way and then checked the oil. NOTHING showed on the dipstick. I poured a quart and a half in and finally it registered in the middle of the dipstick. I went to start the car again and still no luck. When I turn the key it sounds SIMILAR to a car that wants to start on a low battery. However, the sound doesn't sound the exact same to me. It's very similar but for some reason I just feel like it's "different." Any ideas? The gentleman that towed the car home for me said he thought it sounding like the timing belt needed to be replaced. Would low oil cause this? What can I do to check what the issue is or what likely needs to be repaired? -------------------- digitalctrl
Lansing Computer Repair Laptop Repair Geek Squad Alternative Don't hate me...I'm a friendly n00b. :) |
Jul 9, 2009 - 2:42 PM |
Enthusiast Joined Jul 12, '08 Currently Offline Reputation: 5 (100%) |
did you check if you're getting spark, fuel, and compression? if those things are there then check if your timing belt snapped. a locked engine wouldnt be able to crank since all the internals would have welded together
Jul 10, 2009 - 11:08 AM |
Enthusiast Joined Jul 28, '06 From Delaware Currently Offline Reputation: 0 (0%) |
I drove my mother's 1990 Celica ST to my doctor's appointment without any issues. I stopped to get gas on the way and still made it there without any problems. After an hour, I jumped in and started it and and pulled up to the road to make a turn. Just as I got ready to turn the car stalled out. I went to start it back up and it just wouldn't do it. I tried a few more times to start it but no luck. The battery is fine, the alternator is new. I moved the car out of the way and then checked the oil. NOTHING showed on the dipstick. I poured a quart and a half in and finally it registered in the middle of the dipstick. I went to start the car again and still no luck. When I turn the key it sounds SIMILAR to a car that wants to start on a low battery. However, the sound doesn't sound the exact same to me. It's very similar but for some reason I just feel like it's "different." Any ideas? The gentleman that towed the car home for me said he thought it sounding like the timing belt needed to be replaced. Would low oil cause this? What can I do to check what the issue is or what likely needs to be repaired? pull off the valve cover. timing belt is on the lefthand side connected to the cam pulley. |
Jul 11, 2009 - 11:52 AM |
Enthusiast Joined Jul 24, '08 From Canoga Park CA. Currently Offline Reputation: 0 (0%) |
If you remove the nut on the upper right of the timing cover (plastic) you can peak inside to check it out . If you see the gear with no belt it is
broken. I don't think your problem is under the valve cover(metal). If the belt is not broken sounds like a cap and rotor problem. Then I would look at fuel pump. |
Jul 15, 2009 - 1:37 AM |
Enthusiast Joined Apr 14, '09 From Moreno Valley, CA Currently Offline Reputation: 0 (0%) |
I would check the battery, too. A jump is an easy place to start. Reason why I mention this is the new alternator. If the battery was run for a while with the old alternator, it may have caused it burn out. I have had this happen before.
BTW - if a quart of oil put it on the dipstick, you are probably two quarts low, which should do any damage in the short term (really, though have your mom check her oil). |
Jul 23, 2009 - 3:33 PM |
Enthusiast Joined Jul 21, '09 From Indianapolis, IN Currently Offline Reputation: 0 (0%) |
I would check the battery, too. A jump is an easy place to start. Reason why I mention this is the new alternator. If the battery was run for a while with the old alternator, it may have caused it burn out. I have had this happen before. BTW - if a quart of oil put it on the dipstick, you are probably two quarts low, which should do any damage in the short term (really, though have your mom check her oil). I ran into a similar problem.. I changed distributor, Wires, PTS, ECU and still having problems.. My car would start and then die.. So please let me know if you have fix yours and how.. Thanks.. |
Jul 23, 2009 - 4:21 PM |
Enthusiast Joined Dec 19, '07 From tx Currently Offline Reputation: 22 (100%) |
To check for timing belt failure remove the distributer cap and try to start the engine. If the rotor spins the belt is not broken - move on to the next thing
-------------------- ENGINE: '93 RC 3S-GTE/WRC CT-20b [18-20PSI] PERF: TRD/HKS/ARP/NGK/MSD/ACT/Blitz/STRI/APEX'i/TwosRus/GReddy/Magnaflo/KOYO SUSP: Tein/Bilstein/SusTech/ INT: SS-III SEATS/Toyota Hyper Sports EXT: WRC/TRD/404 Its a safety feature so that people like you don't end up killing themselves or everyone around them. Slow down Paul Walker. 6GC Chat - Go there: [url="http://www.griffgirl.com/forum/chat/index.php[/url] |
Aug 5, 2009 - 4:06 PM |
I would check the battery, too. A jump is an easy place to start. Reason why I mention this is the new alternator. If the battery was run for a while with the old alternator, it may have caused it burn out. I have had this happen before. BTW - if a quart of oil put it on the dipstick, you are probably two quarts low, which should do any damage in the short term (really, though have your mom check her oil). I ran into a similar problem.. I changed distributor, Wires, PTS, ECU and still having problems.. My car would start and then die.. So please let me know if you have fix yours and how.. Thanks.. Well, mine was the battery and when I replaced it I was fine. If it is turning over and then dying it could be a handful of things from a vacuum leak, the idle to a problem with the fuel delivery. Have you tried starting it and then holding down the gas to force it to maintain a high idle? If so, what did that do? |
Aug 5, 2009 - 8:05 PM |
To check for timing belt failure remove the distributer cap and try to start the engine. If the rotor spins the belt is not broken - move on to the next thing ^ that is the way you can check the timing belt. But really problem usually lies in spark or fuel. Anything part of your ignition, test your spark plugs, wires, cap, rotor, distributor assembly, igniter, etc. -------------------- 94 Celica GT
Aug 6, 2009 - 12:33 PM |
I would check the battery, too. A jump is an easy place to start. Reason why I mention this is the new alternator. If the battery was run for a while with the old alternator, it may have caused it burn out. I have had this happen before. BTW - if a quart of oil put it on the dipstick, you are probably two quarts low, which should do any damage in the short term (really, though have your mom check her oil). I ran into a similar problem.. I changed distributor, Wires, PTS, ECU and still having problems.. My car would start and then die.. So please let me know if you have fix yours and how.. Thanks.. your issue sounds like fuel pump -------------------- QUOTE "And, as always, your friendship, help, and dedication to the advancement of Texas Celica dominance is GREATLY appreciated. Thanks bro." -DEATH 1994 GT: V6 swap, 5speed E53 W/ LSD, All Power, now RED 1995 ST: SOLD @273k miles, Auto, all power, CarPC, White 1994 ST: Totaled, 5spd, all power, Red RIP 07/09/09 @ 241,810 1994 Lexus LS400: This is my new DD |
Aug 13, 2009 - 1:14 PM |
Enthusiast Joined Apr 18, '06 From Calgary, Canada Currently Offline Reputation: 37 (100%) |
WALKER & I just popped off the disty cap and tried to crank it but the rotor didn't even flinch...
So - definately the Timing Belt then? It was about time for it to go anyways... lol -------------------- |
Aug 13, 2009 - 2:41 PM |
WALKER & I just popped off the disty cap and tried to crank it but the rotor didn't even flinch... So - definately the Timing Belt then? It was about time for it to go anyways... lol def timing belt. low oil would not cause that, though im sure it didn't help your motor any. -------------------- QUOTE "And, as always, your friendship, help, and dedication to the advancement of Texas Celica dominance is GREATLY appreciated. Thanks bro." -DEATH 1994 GT: V6 swap, 5speed E53 W/ LSD, All Power, now RED 1995 ST: SOLD @273k miles, Auto, all power, CarPC, White 1994 ST: Totaled, 5spd, all power, Red RIP 07/09/09 @ 241,810 1994 Lexus LS400: This is my new DD |
Aug 13, 2009 - 2:51 PM |
I WALKER & I just popped off the disty cap and tried to crank it but the rotor didn't even flinch... So - definately the Timing Belt then? It was about time for it to go anyways... lol def timing belt. low oil would not cause that, though im sure it didn't help your motor any. Oh sry - I'm not the thread starter. My oil is tippy-toppy. Thanks for the info regarding the timing belt tho. I appreciate it. -------------------- |
Lo-Fi Version | Time is now: November 23rd, 2024 - 6:07 AM |
