> Nearly all done on my convertible
post Jul 10, 2009 - 11:46 AM
jeffrosie
Joined Sep 11, '08
From Surrey Unitedkingdom
At long last my engine and gearbox conversion is complete and in the car.
All up and running.
Last thing to do on the engine is plumb-in the std DV.
It has 2 connectors on it - anybody know how??
post Jul 10, 2009 - 12:29 PM
jeffrosie
Joined Sep 11, '08
Got the E153 box with std MR2 LSD and obligatory MR2/ST185 axles.
post Jul 10, 2009 - 3:16 PM
95st-celica
Joined Mar 29, '07
From Philly
damn dude that is a georgous vert..more pictures please!!
1988 Dodge Aries K (sold)
post Jul 10, 2009 - 5:13 PM
jeffrosie
Joined Sep 11, '08
Will try and get more pics tommorow if it doesn't rain.
Map sensor is ST205 and ecu is MR2 rev3 3SGTE.
post Jul 10, 2009 - 5:43 PM
jeffrosie
Joined Sep 11, '08
95st-celica, just reading your car spec - impressive. Just want to know from where did you get your clear dood courtesy lenses and if they are a Toyota item do you have a part# for them. Thanks
post Jul 11, 2009 - 12:12 AM
Mstoochn
Joined Apr 27, '09
From West Coast Canada
im confused, stock air box?
post Jul 11, 2009 - 2:35 AM
6gsillyca
Joined Jan 13, '06
From UnderTheGround403
Nice clean engine bay..how long did your swap take?
BTW the door lights are from a tundra truck.
post Jul 11, 2009 - 8:36 AM
jeffrosie
Joined Sep 11, '08
intercooler pic
This post has been edited by jeffrosie: Jul 11, 2009 - 8:37 AM
post Jul 11, 2009 - 8:41 AM
jeffrosie
Joined Sep 11, '08
Gonna see if the GT4 rear shock assembly fits the GT as they are shorter and will hold the lowering springs in firmly.
Might even try and fit the ST205 rear ARB as its 17mm thick instead of the 16mm GT - thats if it goes over the fuel tank pipe along with the polly bushes for the ARB.
post Jul 13, 2009 - 4:05 PM
jeffrosie
Joined Sep 11, '08
So the std GT4 ST205/185 rear shocks dont fit as the 2 bolt holes to the hub at the lower end are different frown.gif.
Also the std ST205 rear ARB won't fit as its a completely different shape frown.gif
im confused, stock air box? (mstoochn)
Only till running in is done - then a better DV and induction kit
This post has been edited by jeffrosie: Jul 13, 2009 - 4:06 PM
post Jul 13, 2009 - 8:48 PM
pipes
Joined Apr 23, '08
From boston MA
ARB??
post Jul 14, 2009 - 1:52 AM
jeffrosie
Joined Sep 11, '08
Anti Roll Bar
post Jul 14, 2009 - 6:43 AM
nice work jeff, looks great!
post Jul 22, 2009 - 1:32 PM
jeffrosie
Joined Sep 11, '08
ST185 rear brakes fitted.
Will soon fit the fronts when I find them somewhere within my messy garage.
They are only a couple of mm larger, but will use them as they have the option of Red/Yellow Stuff pads.
Std GT calipers only get the option of Green Stuff pads.
post Jul 22, 2009 - 1:37 PM
Sinyk
Joined Oct 4, '06
From Kelowna, BC Canada
Your manifold heat shield is amazing. I like that about as much as I like a chrome plated one. thumbsup.gif
I hope the heat doesn't wreck the colour.
post Jul 22, 2009 - 3:33 PM
jeffrosie
Joined Sep 11, '08
Think the paint will be OK as its been primed with heat resistant primer and got a heat resistant base coat on after which the RED was applied in very light coats before finishing with a gloss coat.
post Jul 22, 2009 - 11:28 PM
CelicaST_CALI
Joined Feb 28, '07
AMAZING!!!!great looking vert,pics PLEASSEEE
BANNED. for life, you moron.
Lo-Fi Version Time is now: November 28th, 2024 - 9:33 AM
