Enthusiast ![]() ![]() Joined Feb 2, '09 From new orleans La. Currently Offline Reputation: 5 (86%) ![]() |
I had my car swapped somtine ago and I snapped a motor mount stud on the front passenger side fender, by the timing cover.
Well I noticed somtime ago that this mount only had 1 stud in it and bolted down. The other was never installed. My question is what the proper way to dod this. Does just one stud fit into the engine bracket? When it was on I counld see the other hole and it did not line up good with the engine bracket. You guys with a 3sgte swap how is yours 1 bolt or 2 in on the mount i am talking about? I managed to put 2 in but the mount is cocked to the side now. The only way to line the mount back straight is to put only 1 stud back in and leave the other empty like it was. Any one know what I mean? |
you need a 5sfe bracket and mount.
there is one stud and nut that locates the motor, and 2 bolts, a larger 14mm bolt, and a small 12mm bolt. -------------------- Former Team 5SFTE pro member ;)
![]() Here is the mount thats on there. SEE the 3 holes but there are only 2 on the engine where they mount up |
that looks like the correct mount.
but, sounds like you still have the 3sgte engine bracket. -------------------- Former Team 5SFTE pro member ;)
that looks like the correct mount. but, sounds like you still have the 3sgte engine bracket. I was wondering, Does the engine bracket unbolt behind the timeing cover? You gotta talke the cover off? I really want this mount right. It dont give no issues but if it is not right I want to fix it. Is it suppose to have a 2.2l engine mount on the 3sgte? If so Where can I get one? |
You dont have to take the cover off. There are 3 bolts that connect the bracket to the engine. You can use any 6th gen 5sfe bracket and motor mount. Once you swap those over, all 3 motor mounts will line up.
So the right way to do this is to use the 5sfe mount and the 5sfe engine bracket and just bolt the 5sfe engine bracket up to the 3sgte and I am good to go? This is the fender motor mount I am talking about, Is there any other right way the other mounts should be done? I think the rest is all 5sfe mounts. I am trying to get the engine as solid as I can. I read of others useing st205 mounts is this the same or better? And how about useing what I got now fix the engine bracket and get some motor mount inserts from two r us?
So the right way to do this is to use the 5sfe mount and the 5sfe engine bracket and just bolt the 5sfe engine bracket up to the 3sgte and I am good to go? Yes that's it. Then just buy the poly inserts for the front and rear motor mounts and you're good to go. -------------------- 15PSI - 30MPG - Megasquirt Tuned
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 29, '07 From Philly Currently Offline Reputation: 11 (100%) ![]() |
x2 on the polly urathane inserts....for the money, you cant beat it...i love mine
-------------------- ![]() I"M NOT A TOYOTA FAN, IM A FANATIC 1984 accord hatch 5 speed (T-Belt)-Junkyard 1991 VDUB jetta wolfsburg Ed. 5 speed (clutch)-junkyard 1988 Dodge Aries K (sold) 1969 Chevy El camino - Traded for celica 1991 Dodge Daytona-Traded for Celica 1988 Chevy Camaro-Work in Progress 1989 Ford Mustang LX 5.0 - For Sale 1995 Toyota Celica-Work in Progress |
Lo-Fi Version | Time is now: April 22nd, 2025 - 8:32 PM |
