> double piston brake
post Jul 12, 2009 - 10:25 PM
im considering these calipers from an ssIII, would they be a direct bolt on? where could i get the parts to refurbish them?
post Jul 13, 2009 - 12:20 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
SSIII has superstrut suspension... so probably not a bolt on. I imagine it would require similar modifications as the GT4 calipers do to bolt onto the MacPhearson knuckle. I think the old ST165 calipers, which are bolt on (but you'll probably still need a rotor), are twin piston... but that doesn't mean it'll brake any better either.
post Jul 13, 2009 - 1:39 AM
Rusty
Joined Nov 5, '07
From New Zealand
how about the same 2 pots from the SS-II, same suspension easier swap
post Jul 13, 2009 - 6:22 AM
well thats the thing, im not sure if this is an ssii or ssIII, i just assumed. well dont want to risk. well contact the seller.
post Jul 13, 2009 - 1:21 PM
jeffrosie
Joined Sep 11, '08
From Surrey Unitedkingdom
SSII has mcphearson fronts and the SSIII has superstrut fronts.
post Jul 17, 2009 - 4:04 AM
Buffalo
Joined May 24, '08
From Limassol, Cyprus
QUOTE (njccmd2002 @ Jul 12, 2009 - 11:25 PM) *
yes they will be a direct bolt on....
post Jul 17, 2009 - 10:12 AM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
the c4 vettes has the same identical cage as the st185 calipers, but are twin piston. Its also aluminum. Has anyone ever thought of using that on their 6th gen? You'd have to use the 277mm rotors though.
94 Celica gt white (sold)
post Jul 17, 2009 - 6:06 PM
Rusty
Joined Nov 5, '07
From New Zealand
Lo-Fi Version Time is now: January 10th, 2025 - 3:27 PM
