Enthusiast ![]() Joined Jun 24, '06 From Houston.TX Currently Offline Reputation: 0 (0%) ![]() |
My motor stopped running like 2 days ago (5sfe). I came across this 3rd gen 3sge(just the motor) and i was wondering would i be able to run it on my stock 5s wiring harness and ecu.
Enthusiast ![]() ![]() ![]() Joined Apr 27, '09 From West Coast Canada Currently Offline Reputation: 0 (0%) ![]() |
My motor stopped running like 2 days ago (5sfe). I came across this 3rd gen 3sge(just the motor) and i was wondering would i be able to run it on my stock 5s wiring harness and ecu. you cant, you would need to order a new ECU and have a harness built. sorry if that bursted your bubble |
what do you mean built a wiring harness
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Nov 5, '07 From New Zealand Currently Offline Reputation: 3 (100%) ![]() |
the 3S has more sensors compared to the 5s, also you will need the rpm gauge cluster as this one has 0-9,000rpm, not your standard 0-8,000rpm and also has a redline of 7,250rpm
Lo-Fi Version | Time is now: February 24th, 2025 - 7:50 AM |
