![]() Enthusiast ![]() ![]() ![]() Joined May 29, '09 From Lake Ariel, PA Currently Offline Reputation: 4 (100%) ![]() |
So i was taking the wood grain on my dash off today and to get the extra adhesive off i used googone, never use it on your car. I learned this the hard way, cuz it ate through the gloss on my dash trim and also through the prnd21 panel on my auto trim. I can deal with the trim and just sand/paint it but the auto shifter panel is messed up. Does anyone have one that they could sell me cheap?
-------------------- ![]() Representing the Convertible Crew since 2008 |
Auto shifter trim is messed up? Time for a manual swap then.
![]() -------------------- '97 ST \ Eibach \ KYB \ Kenwood \ Alpine \ Cusco \ OEM+ [sold 10/18]
'93 MX-5 LE |
Enthusiast ![]() ![]() Joined Apr 20, '09 Currently Offline Reputation: 4 (100%) ![]() |
Yeah, Goo Gone and Goof Off fog the hell out of plastics. I'm fairly certain there's a way for you to be able to re-clear the plastic piece you're talking about... I think you could probably sand it down and polish it with some fine-grit sandpaper and compound. If not, flame-polishing it might also work.
I assume you know how to get it out? I never could figure out how to get that panel out the "proper" way. I always got stuck with getting the shifter knob out. Do you happen to know where the overdrive switch is plugged into so you can pull the shifter right out? -------------------- ~Moving on to a 2002 Corolla S~ R.I.P Tom Celica - 1994-2010 |
Lo-Fi Version | Time is now: February 16th, 2025 - 4:57 PM |
