Jul 25, 2009 - 2:06 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 12, '08 Currently Offline Reputation: 5 (100%) |
Hey everyone heres the backstory:
upon taking my 99gt our of winter storage, I gave it the once over to prepare for the thousands upon thousand of miles i was going to rack up this summer. I changed the oil, checked all the fluids/filters/plugs ect and everything seemed to have held up very well. The car ran like new From there i drove the car around all day and there were no issues whatsoever (even after several light thrashings on a twisty road in my area). The following day I was coming back from my friends house and my clutch pedal stuck to the floor. uh oh there goes my slave cylinder, or so i thought. It ended up being my clutch master. I changed both. I also bled the whole system about 4 times thoughout the the whole troubleshooting process. In the end the celi swapped gears effortlessly again on to my question: the fluid i filled the system with was DOT III CLEAR fluid (as stated on the master cyl cap). now however, this clear fluid has turned a fantastic shade of brown ![]() compare this with my brake master cylinder where i used the same brand around the same time i did my clutch ( i was on a roll) ![]() nice and clear so why would the fluid in my clutch system turn brown, while the fluid in my brakes stayed looking like new? at first i thought that it may have been some gunk inside the lines that has since broken up, but that doesnt make sense since i bled the system FOUR times. should be as clean as it gets in there could it possibly be that the master and slave cylinders are wearing in, thus dirtying up the fluid a bit? input and opinions are appreciated -Luke -------------------- ![]() |
Jul 26, 2009 - 3:00 AM
bump
is it possible that i've stumped the 6gc community? -------------------- ![]() |
Jul 26, 2009 - 7:08 AM
that is odd, how bad black was the old fluid? it is possible that the other cylinder is on its way out and thats just some sediment stirred up from inside of it, inside the lines, and inside the reservoir.
Jul 26, 2009 - 12:15 PM
Enthusiast ![]() ![]() ![]() Joined Sep 19, '08 From Michigan Currently Offline Reputation: 4 (75%) |
Take out some of that "dirty" fluid and put it in a small white Dixie cup. Then take out some of the brake fluid and put in another Dixie cup to the same height. Now compare.
Brake reservoir is shallow. Clutch reservoir is quite deep, so you are seeing a tall column of fluid, which will look darker. Just like a full cup of tea will look darker than just a little bit of tea on the bottom of a white cup. If equal quantity still looks dirty, then you need to keep flushing until all dirt is gone. |
Jul 26, 2009 - 2:17 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 3, '04 From Portsmouth, RI Currently Offline Reputation: 33 (100%) |
It's definitely dirty, it shouldn't look like that.
Is the master cylinder new, used, re-manufactured, Toyota or aftermarket?? There is a chance the brake fluid is breaking down the seals in the new master cylinder. Also check the condition of the rubber clutch line, maybe the fluid is breaking down that line from the inside. -------------------- |
Jul 26, 2009 - 2:32 PM
both the master and the slave have been replaced with new autozone units. I tried getting toyota parts but they could only get the master and that would take over a week (i needed the car rlly badly). also, keep in mind that i flushed the hell out of the system to clean it out because it was dark before as well.
the idea that one column of fluid is darker than the other due to the depth of the reservoir is a good idea but does not apply in this case. were talking about an inch or two of difference, not the several hundred feet that it would probably take to make such a dramatic effect. you cant tell in the picture but the fluid gets its color from tiny microscopic specs of...black. what rubber line? theres a rubber line? what you're saying makes alot of sense hurley, care to eloborate? This post has been edited by enderswift: Jul 26, 2009 - 2:39 PM -------------------- ![]() |
Jul 26, 2009 - 3:13 PM
found the rubber hose. obviously its purpose is the allow the engine to move without sending the shock to the hard lines. I checked it out and it looks great. no hard spots, no spongy spots. all around clean.
what else could it be?? -------------------- ![]() |
Jul 26, 2009 - 5:01 PM
The black specs can only be bits of the rubber from the clutch hydraulic system (unless something from outside got in the system of course). There really isn't much else it could be besides the seals in the master cylinder or the rubber on the inside of the rubber line. The clutch hydraulic system is very simple and there isn't much to it, I'm sure you are well aware having replaced both the master and slave cylinders, but it goes master cylinder-->hard line-->rubber line-->hard line-->slave cylinder... that's it. Most likely its the cheap seals inside the autozone master cylinder. The only other thing it could be is the brake fluid you used is more corrosive to the rubber things in the system than what was in it last, which will also cause problems later, but as you said you used the same fluid in the brake system and that's just fine.
This post has been edited by hurley97: Jul 26, 2009 - 5:02 PM -------------------- |
Jul 26, 2009 - 6:59 PM
The black specs can only be bits of the rubber from the clutch hydraulic system (unless something from outside got in the system of course). There really isn't much else it could be besides the seals in the master cylinder or the rubber on the inside of the rubber line. The clutch hydraulic system is very simple and there isn't much to it, I'm sure you are well aware having replaced both the master and slave cylinders, but it goes master cylinder-->hard line-->rubber line-->hard line-->slave cylinder... that's it. Most likely its the cheap seals inside the autozone master cylinder. The only other thing it could be is the brake fluid you used is more corrosive to the rubber things in the system than what was in it last, which will also cause problems later, but as you said you used the same fluid in the brake system and that's just fine. haha seriously, there is only so much that can go wrong in a system like this. well, I decided to bleed the whole thing all over again and you would not believe the gunk that came out, imagine the look of fine steel shavings in a blown engines oil, only black. If thats the result of piston seal deterioration then i want my money back; cuz that is not gonna last more than a few months at this rate. Cant wait to lose control of my clutch making a left turn in a busy intersection moral of the story: always, always buy OEM parts. thanks to everyone who chimed in and offered their opinion. this is why 6gc rocks. -Luke This post has been edited by enderswift: Jul 26, 2009 - 7:04 PM -------------------- ![]() |
Jul 28, 2009 - 7:08 AM
Enthusiast Joined Mar 7, '09 From Milton Florida Currently Offline Reputation: 0 (0%) |
my cars the same way the master cylinder got really dirty when my clutch went out, and its been black since then, my dad is a MDT for toyota and he said its nothing to worry about
-------------------- 96 3sgte Celica
93 3sgte MR2- 2.1L, billet 6262 06 Mazdaspeed 6- DD |
Jul 31, 2009 - 11:59 PM
update:
its been less than a week since i flushed out the the old nasty fluid with some fresh dot III. guess what. its turning dark again! what is going on??? -------------------- ![]() |
Oct 12, 2009 - 12:04 PM
Hey everyone, I'm bringing this thread back because I still have the same issue and have been doing research on what could possibly be the cause
1: It seems this occurs across all makes of cars and bikes too. 2: Some people assert that the brake fluid reacts with low quality aluminum to produce a dark color (has anyone heard something like this?) 3: Fluid turns black when exposed to moisture.. (i poured water into a glass of fluid and watched it over 3 days. nothing happened to it) 4: Heat from the engine causes the fluid to coke (Id imagine this would be a problem for motorcycles more than cars...) 5: cheap seals within master and slave cylinders are wearing away. (definitely possible, but wouldn't that cause and internal leak? and my clutch works great!) anyone care to troubleshoot again?? -------------------- ![]() |
Oct 12, 2009 - 2:54 PM
Enthusiast ![]() ![]() ![]() Joined Jul 9, '08 From California Currently Offline Reputation: 5 (100%) |
Wish I could offer some help, but I honestly don't know about this problem.
I am curious though, how much were the master and slave cylinders? Did you install them yourself? How long did it take/how much of a pain was it? My slave is going out something fierce (pedal stuck down, have to kick it repeatedly to get it to pop back up) and I'm trying to figure out if I should do the work myself, or just pay a local shop. Hope you find the issue, -TC -------------------- Live your life for yourself. Don't hold back for anything or anyone.
Oct 12, 2009 - 4:00 PM
if i remember a new master was $50 and a new slave was ~$25. I installed both of these parts myself and it is a really simple affair. Both parts are fitted with only two bolts. Still, the slave is annoying to get to especially when the engine is hot. the master on the other hand requires you to contort under your dash. Easy but annoying is the best way to put it. Id say it can be all done in an afternoon if you have to to run to get fluid/take a break/ wait for engine to cool down. make sure you have a friend to help you bleeding! and save your reciepts in case the fluid starts to turn cloudy all the time.
This post has been edited by enderswift: Oct 12, 2009 - 4:01 PM -------------------- ![]() |
Oct 12, 2009 - 6:41 PM
flush some more fluid through, it will turn clear. remember, it only takes a very little bit of black gunk to turn the fluid dark.
Oct 13, 2009 - 12:29 AM
sir i believe the flush count is up to 7 now.
Oct 13, 2009 - 4:38 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 16, '03 From Bay area Currently Offline Reputation: 0 (0%) |
maybe its the clutch fluid you are using is too agressive and eating way at your seals.
Have you tried a different clutch fluid? prestone or OEM toyota fluid? |
Oct 13, 2009 - 7:28 AM
take the lines off and flush them out with brake cleaner, new slave, new master, new reservoir, bleed with clean fluid, i bet it stays clean.
Oct 13, 2009 - 10:21 AM
The lines have been flushed, the master and slave are new.
I was thinking that the fluid is too agressive too.. but how could it be THIS agrressive? i've never heard of brake fluid destroying parts that are meant to withstand it! -------------------- ![]() |
Oct 13, 2009 - 10:33 AM
how did you flush the line? you need to really get crazy on it, a can of brake cleaner and 100psi shop air, spray and blow multiple times or just replace it. replace everything and you'll have crystal clear brake fluid, replace the car too. a new one will have clear clutch/brake fluid.
srsly, you're freaking out about nothing dude. does the clutch work correctly? yes? stop worrying. dot3 is all you need, you can get brake fluid test strips that will tell you the water content and acidity of the fluid. does it test as OK? yes? stop worrying. -------------------- |
| Lo-Fi Version | Time is now: May 18th, 2026 - 2:36 PM |
