> Antenna problem
post Jul 26, 2009 - 5:58 PM
nics
Joined Feb 15, '08
From Royal Oak, MI
I was in the drivethru and i decided to list to fm radio, so i did and after the antenna went all the way out, its has a weird noise like it was stuck. The motor is going on still even the antenna was up already. i tried to put it back to cd so that antenna would go down but it wouldnt. i had to go and push it lightly so it would go down. Is my antenna motor bad or is it just the antenna. thanks
God made man....
Everything else...
Made in China
post Jul 27, 2009 - 2:41 AM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
Probably the antenna mast, which is pushed up and pulled down via a toothed vinyl strap. If the strap breaks the motor will run but -- obviously -- won't move the antenna.
It's an easy replacement, should be less than $30 for the mast from your dealer. Pull the antenna and motor, then remove the antenna mast. Work it up and down and you should be able to tell if the strap has broken or not. If not, likely a motor issue. However, 15-year-old vinyl is prone to snapping.
post Aug 19, 2009 - 6:35 PM
fenderdave
Joined Jul 23, '09
From UK
HI
Slightly off your topic, but my antenna goes up once the key gets turned and the only way to retract it is to switch the engine off,
Does it sound like the previous owner hasn't connected a wire correctly to the Head unit?
post Aug 19, 2009 - 8:49 PM
nics
Joined Feb 15, '08
From Royal Oak, MI
QUOTE (Galcobar @ Jul 27, 2009 - 12:41 AM) *
ok but my antenna goes up and down. I mean it goes all the way up and you still hear the motor moving it. when i try to put it down i need to push it a little bit. it only ahs one belt right?
QUOTE (fenderdave @ Aug 19, 2009 - 4:35 PM) *
HI
is it on radio or on cd player?
God made man....
Everything else...
Made in China
post Aug 20, 2009 - 7:32 AM
fenderdave
Joined Jul 23, '09
From UK
QUOTE (nics @ Aug 19, 2009 - 9:49 PM) *
HI
Its the standard Sony CD player that came as standard on my model, but its in such good condition for a 10 year old head unit that i suspect the previous owner had probably swapped if for an after market one and has put it back in when they sold it.
Lo-Fi Version Time is now: January 10th, 2025 - 5:11 PM
