> Clutch Chatter Or Bad Tranny ??, S54 Tranny
post Jul 31, 2009 - 4:57 PM
Remy
Joined Jan 25, '06
From MN
Hey all have a quick question while on the drive way with the ebrake down and in 1st gear if I let go of the clutch slowly without giving it gas the tranny terribly shakes and slowly crawls forward is that clutch chatter or do I just have a bad tranny, bearing, pressure plate, misc... all together ?? And yes I'm aware that if you don't give it gas and let off the clutch it'll stall and cause vibration/shutter on you but this is a different kind of feel in case someone wants to be a smartass lol.
-More info on the tranny-
-Clutch was supposedly change a year ago before I bought it so about 4 years old I drive like a grandma so I don't beat on it either.
-It's written 96 with special auto marker so its a used tranny thats been swapped so not the original tranny.
-Unknown Miles on the swapped s54 tranny.
-Leaked tranny fluid like crazy the first year I bought it didn't know about it because didn't drive it much my bro drove it and he didn't tell me about it although now I've fixed the problem. He didn't care because it wasn't "his" car....and he's a honda guy so he didn't really approve of the car and when I bought the car it was runnin rough, misfiring, shorted and burned wire harness and leaking oil and later on found out about the tranny fluid leak.
-I'm sure some things been damaged because of that I always wandered why it was so hard to shift when I first purchased the car, I though it was because of the short shifter.
-Ran penzoil syncromesh for 2 years, now runnin royal purple syncromax 75w90 alot smoother shifting now took 1 month to break in the tranny fluid haha...what I mean is that didn't notice any difference till 1 month later after the switch.
-I believe this is whats causing my vibration on acceleration problem too u really notice it if your going uphill.
-Full tune-up have been done on this car the start of summer.
Could use some advice or second opinion on what it is Thanks all.
"To Protect And To Serve The Wealthy" -POLICE
post Jul 31, 2009 - 5:47 PM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
<--- smartass here biggrin.gif if you dont give gas period the car will stall and shake laugh.gif how far is the pedal up when it starts to shake?? you can adjust the pedal play. how low was the gear oil when it was leaking??? the s54 can take alot of beating like Death said, mines is still alive wink.gif just an insight to what i do to the car biggrin.gif i would adjust the pedal play and play around with it more. OEM clutches should last 80k miles while stage 2 and up clutches only dont last much longer than 50k miles. it also could be in the "maybe its time" age
post Jul 31, 2009 - 6:24 PM
Remy
Joined Jan 25, '06
From MN
Actually it still vibrates and shake even if I give it gas even if I floor it in 1st gear I still get that vibration, its coming from the tranny not the engine u can feel both axles shake and jerk trying to accelerate. tongue.gif
post Jul 31, 2009 - 7:18 PM
your car is fine. sounds like you need new motor mounts though.
post Jul 31, 2009 - 8:49 PM
Remy
Joined Jan 25, '06
From MN
A year ago I took both front and rear mounts out the front looked new no tears or anything but the rear mount was cracked and damaged I replaced the rear mount with a brand new oem toyota rear mount also installed kirk's poly mounts f/r while I was down their. The left/right mounts are still in good condition too.
post Aug 1, 2009 - 3:46 AM
Rusty
Joined Nov 5, '07
From New Zealand
hmm maybe check your struts aswell (front strut towers) check the top nut
post Aug 1, 2009 - 7:21 AM
Remy
Joined Jan 25, '06
From MN
The strut mounts were properly torq'd when I installed my new bilsteins and springs this spring. It only vibrates and shakes when the clutch is engaging with or without gas even revving at idle nothing shakes or vibrates but once you slowly let go of the clutch the front starts shakin really bad. This only happens in 1st gear.
post Aug 1, 2009 - 8:03 AM
sounds like clutch chatter to me.
Lo-Fi Version Time is now: December 4th, 2024 - 1:21 PM
