What's going on?, Cat question |
Aug 7, 2009 - 8:07 PM |
Enthusiast Joined Jan 20, '08 From East Coast Currently Offline Reputation: 1 (100%) |
My brother has a 7th gen celica GTS and says he needs a new cat because he hollowed it out from regular driving. I say he just needs a new O2 sensor. This is why...he has no problems whatsoever while driving nor does he have any sounds at all from the cat. He does have a check engine light on though. Anyway, is it in any way possible for someone to simply hollow out their cat by driving yet have no side effects in any way? maybe I am wrong but I don't think so.
Aug 7, 2009 - 8:12 PM |
Enthusiast Joined Mar 8, '08 From Orlando, Florida Currently Offline Reputation: 14 (100%) |
I believe excessive heat can basically "melt" the catalyst over time, excessive heat from the engine being improperly tuned, something with like too much unburned fuel entering the exhaust.
a local exhaust shop saved some insides of cat-cons that this had happened to, and it really smashed them down, i would *think* that the exhaust flow should be pretty obstructed from that, and that's probably what is throwing the code. This post has been edited by samir0189: Aug 7, 2009 - 8:32 PM -------------------- ◊◊◊ My F/S Thread! ◊◊◊
Lo-Fi Version | Time is now: November 24th, 2024 - 4:03 PM |
