Help!, What is this light green sensor? |
Aug 8, 2009 - 2:20 AM |
Enthusiast Joined Jul 30, '08 From NYC Currently Offline Reputation: 0 (0%) |
It's located right next to the EGR Valve. I believe it is supposed to have a vacuum hose coming from it, going to somewhere else as well. This is a 5sfe engine. I need to know what that sensor is so I can replace it. Obviously mine is effed. Any help appreciated.
Thanks! What Am I? This post has been edited by joeladam02: Aug 8, 2009 - 2:23 AM |
Aug 8, 2009 - 3:23 AM |
Enthusiast Joined Apr 27, '09 From West Coast Canada Currently Offline Reputation: 0 (0%) |
It's located right next to the EGR Valve. I believe it is supposed to have a vacuum hose coming from it, going to somewhere else as well. This is a 5sfe engine. I need to know what that sensor is so I can replace it. Obviously mine is effed. Any help appreciated. Thanks! What Am I? unless i am mistake that is no sensor, its just a vacum cap, looks like a 3/8" cap. pretty common but mine are black! |
Aug 8, 2009 - 7:34 AM |
It's located right next to the EGR Valve. I believe it is supposed to have a vacuum hose coming from it, going to somewhere else as well. This is a 5sfe engine. I need to know what that sensor is so I can replace it. Obviously mine is effed. Any help appreciated. Thanks! What Am I? unless i am mistake that is no sensor, its just a vacum cap, looks like a 3/8" cap. pretty common but mine are black! That makes sense. There is no power going to it...just vacuum. Thanks! |
Aug 8, 2009 - 7:42 AM |
Enthusiast Joined Jan 17, '08 From JB MDL, NJ Currently Offline Reputation: 30 (100%) |
Its a gas filter,
This post has been edited by Spider77: Aug 8, 2009 - 8:14 AM |
Aug 8, 2009 - 10:38 AM |
Aug 8, 2009 - 11:59 AM |
does that goto the map sensor? where did the vacuum line goto?
Aug 8, 2009 - 2:03 PM |
does that goto the map sensor? where did the vacuum line goto? Problem is, this arose in an engine swap. I was not there when the first engine was taken out, so I don't know what it was attached to. My brother did the work, and he doesn't remember. Luckily I was able to steal one off of my old motor that was warrantied because the parts store had not sent it back to the vendor yet. But I would still like to know what the hell it is, what it does, and why I can't find a new one anywhere I look. According to the vacuum diagrams it's a gas filter of some sort. Perhaps exhaust fumes? |
Aug 8, 2009 - 4:08 PM |
It does go 2 the map
Aug 8, 2009 - 4:38 PM |
Enthusiast Joined Jan 25, '06 From MN Currently Offline Reputation: 19 (100%) |
Thats where the gas filter is for a 5sfe it should have 2 vac hose connected to it ones to the map sensor and the other is to the FPR.
-------------------- "To Protect And To Serve The Wealthy" -POLICE
Aug 8, 2009 - 6:07 PM |
Aug 8, 2009 - 9:17 PM |
Lo-Fi Version | Time is now: November 24th, 2024 - 4:22 PM |
