> Creating a Memory wire???, Is this possible??
post Aug 9, 2009 - 1:17 AM
legalkid86
Joined Dec 14, '08
From RGV, Texas
hey guys like the topic says ive installed a stereo in my car but for some reason the stereo will not turn on unless i connect yellow and red together as one wire and the thing about it as well i have no memory wire in my car i looked all over and i guess the previous owner tore it apart cause he sd he never got it to work so yeah is there a way i can create a memory cable for i can have my station set already im tired of not having a time in my car (yes my dash panel as well is having issues) i checked all fuses and they look good can you guys give me some pointers i would really appreciate this thanks....
wAkE uP, u'Ll sLeEp WhEn U DiE.....
post Aug 9, 2009 - 2:38 AM
black13
Joined Oct 11, '06
From calgary
For memory wire I think you can just connect a wire to the + terminal of the battery and run it somehow around to the dash. I had to do this for my previous civic. Or find another wire somewhere in the dash and check with a volt meter to see if it gets constant power even when car is off and that should work as well.
post Aug 9, 2009 - 12:17 PM
zonz540
Joined Jul 3, '09
From UT
Id pull from the constant 12v (+) in the steering column. Heres the wire colors for 94-99 celicas.
1999 Toyota Celica Alarm, Remote Starter, Keyless Entry Wiring Information
Constant 12V+ White or Black/Red Ignition Switch Harness
Starter Black/Yellow Ignition Switch Harness
Ignition Black Ignition Switch Harness
Ignition 2 Blue/Red Ignition Switch Harness
Tach Gray Check Connector
Brake Switch Green/White Brake Switch or Driver's Kick Panel
Trunk Pin Blue/Yellow (-) Driver's Kick Harness (Junction Block)
Parking Lights Dark Green (-) Dimmer or Fuse Panel
Head Lamp Red/Black (-) Light Switch
Door Trigger Red/White (-) Driver's Kick Harness Running to Trunk
Door Lock Blue/Black (-) Door Lock Module right of Steering Column
Door Unlock Blue (-) And Green use Both Wires Diode Isolate
Horn Wire Green (-) Steering Column
Windows Up LF=Green, RF=Green/White LR=Green/White, RR=Green
Windows Down LF=Red, RF=Red/Blue LR=Red/White, RR=Red
1999 Toyota Celica Stereo Wiring
Constant 12V+ Blue/Yellow
Switched 12V+ Gray
Ground Brown
Illumination Green
Dimmer n/a
Antenna Trigger Black/Red
Antenna Left Rear
Front Speakers 6 1/2" Doors
Left Front (+) Pink
Left Front (-) Purple
Right Front (+) Light Green
Right Front (-) Blue
Rear Speakers 6 1/2" Side Panels
Left Rear (+) Black
Right Rear (+) Red
Right Rear (-) White
post Aug 9, 2009 - 11:36 PM
legalkid86
Joined Dec 14, '08
From RGV, Texas
thanks
Lo-Fi Version Time is now: November 27th, 2024 - 4:57 AM
