> Grease splatter from stock oil catch breather in the intake [Gen3 3S-G, How do I clean it?
post Aug 10, 2009 - 11:42 PM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
I just converted my stock oil catch tank to free breathing and I noticed a swirl of grease down my intake hose and on the insides of my intercooler ports.
I washed out my intake hose, but want to know how I go about cleaning out the turbo and intercooler insides without removing more parts than my standard half inch ratchet will allow me?
Mike W
269awhp / 273ft-lbs
post Aug 11, 2009 - 12:45 AM
Carb cleaner.
post Aug 11, 2009 - 5:21 PM
delusionz
Joined Feb 11, '08
I've done that on NA to clean out the intake manifold, but is it ok to spray that down the throat of a turbo??
Mike W
269awhp / 273ft-lbs
post Aug 14, 2009 - 3:52 PM
Terracar
Joined Mar 28, '08
From Washignton
I use gasoline to wash out the i/c, but honestly I would not spray carb cleaner down the turbo. Wipe the turbo out as best as you can.
I have never sprayed carb cleaner down a turbo so not sure if it actually will kill a turbo. I would also assume as long as you primed the turbo prior to start up after the cleaning I wouldn't see where damage would occur, but to me it just does not sound like a great combination.
-Terracar
'92 ST185, '88 ST165, '05 Galant LS, '08 Legacy
post Aug 14, 2009 - 4:40 PM
mafix
Joined Aug 13, '09
From MD
just let the carb cleaner dry out before spinning anything.
Lo-Fi Version Time is now: November 27th, 2024 - 1:45 AM
