> Hey guys im back and i need your help!, CAI
post Aug 11, 2009 - 2:25 PM
CheesyLobster
Joined Jul 19, '04
From Los Angeles, CA
So as some of you guys know I removed my turbo for smog and practicality reasons a while ago. Now I am getting bored with the car again so I put back in my custom made K&N cold air intake and it was running and feeling great... until yesterday. I got a check engine light yesterday, and upon doing a little bit of searching on the interwebs I found that CAIs are know to cause lean codes. The thing is, I actually have a SAFC-II still installed from when I had my turbo, just running at 0% adjustment for fuel levels.
My question is, can I adjust the SAFC for low and high throttle levels so that the car doesn't run lean and the CEL doesn't come on? And if so, what % increases should i do for different RPMs? I'm on stock injectors btw. Right now I am thinking like 5-10% increase across the board for lo-points and 10-15$% across for hi-points???
THANK YOUS!
post Aug 11, 2009 - 4:12 PM
DEATH
Joined Dec 19, '07
From tx
A CAI isn't likely to cause a 7A-FE or a 5S-FE to run lean. That's more for MAF cars where the sensor hasn't been properly installed or the alignment of the bracket isn't 100% dead on on the aftermarket CAI causing the airflow reading to be slightly incorrect.
This post has been edited by DEATH: Aug 11, 2009 - 4:12 PM
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
post Aug 12, 2009 - 2:28 PM
CheesyLobster
Joined Jul 19, '04
QUOTE (DEATH @ Aug 11, 2009 - 2:12 PM) *
So might I have a problem like this? I don't understand what you mean my alignment.
post Aug 12, 2009 - 2:31 PM
DEATH
Joined Dec 19, '07
From tx
QUOTE (CheesyLobster @ Aug 12, 2009 - 2:28 PM) *
No - this doesn't apply to you. Your sensor does not require proper alignment within the airflow.
This is why I said it's unlikely that the CAI is your problem. Most likely you just forgot to hook something up or did so improperly
EXT: WRC/TRD/404
Lo-Fi Version Time is now: February 22nd, 2025 - 9:39 PM
