JVT Racing radiator fan installation, Koyo Radiator/JVT Racing fans - how do you install? |
Aug 16, 2009 - 12:43 PM |
Enthusiast Joined Feb 14, '08 From Shelbyville, TN Currently Offline Reputation: 0 (0%) |
Anybody out there know anything about installing aftermarket radiators and fans? I just bought a Koyo radiator - dual core 53mm - specifically for 6th gen Celica. It came with 2 JVT Racing 12" high speed fans. I paid $316 for the raiator/fan package. The radiator is direct OE fitment however the fans do not bolt directly to the radiator nor will they fit into the factory fan housings/shrouds. To make matters worse I can't use the factory fans because of clearance issues now due to the thicker radiator. I've tried and can't even get the radiator to drop all the way down - it's hitting the cruise control module, AC lines, and the exhaust header. Wandering if anybody else has ever gone through this and what did you have to do to make it work. Custom fabrication???? Thanks.
Aug 16, 2009 - 1:21 PM |
tried putting the fans infront?
Aug 16, 2009 - 2:56 PM |
Aug 16, 2009 - 3:19 PM |
relocate the trans cooler? pictures would help.
Aug 20, 2009 - 3:51 PM |
Nevermind - this one should be closed. Got it all mounted. Will post some pics if I get a chance. Thanks.
Lo-Fi Version | Time is now: November 23rd, 2024 - 2:20 AM |
