> e153 vs S54/S51 Hybrid....., can we make the s54 stronger..?
post Aug 17, 2009 - 12:02 PM
was reading in mr2 this, making a hybrid S54/S51. Using the internals from a camry tranny into ours. in the case that e153 is difficult to find or get.
he S54 housing with S51 internals gives you great gear ratios (similar to the E153) without the added weight.
This post has been edited by njccmd2002: Feb 20, 2011 - 2:16 PM
post Aug 17, 2009 - 2:11 PM
jimmykay
Joined Jul 14, '08
From St. Louis
i dont know much about the different transmissions, but isnt the LSD the whole point of getting the e153 transmission?
'99 Celica GT - Sold
'11 Mazdaspeed3
post Aug 17, 2009 - 4:32 PM
QUOTE (jimmykay @ Aug 17, 2009 - 2:11 PM) *
The main reason is gearing a bonus is the mr2 version has the LSD
nj, which camry? Years ect.
post Aug 17, 2009 - 7:23 PM
let me go find that post, thye were talking about same gearing. except the lsd. the beauty is no axle modification.
reading more an more they were talking about a v6 swap...
from their website
I don't find the S54's ratios suitable for the 3VZ/1MZ unless it's solely a track car, but even then, the low top speed will handicap you on a track with long straights.
The E153's axles will bust before the internals break, so you're looking at 500hp+ with that. The S series is known to handle up to 260-275rwhp (supercharged 1MZ), but the differential and pinion gears will fail on hard launches with large racing spec tires.
Personally, I used an S51 because it has a gearset which is more suited to the torque curve of the 3VZ/1MZ even though it was used in conjunction with the Camry/Solara 5SFE.
I know you've studied the ratios, but here they are again.
S51 3.538 1.960 1.250 0.945 0.731 Diff: 3.944 (Camry/Solara I4 M/T)
S54 3.285 1.960 1.322 1.028 0.820 Diff: 3.944 (Euro spec)
S54 3.285 1.960 1.322 1.028 0.820 Diff: 4.176 (US/JDM spec)
E53 3.583 2.045 1.333 1.028 0.820 Diff: 3.625 (92-93 3VZ)
E153 3.230 1.913 1.258 0.918 0.731 Diff: 3.933 (97-01 Camry V6)
E153 3.230 1.913 1.258 0.918 0.731 Diff: 4.285 (91-95 MR2T)
The V6 E153 has the longest gearing of these transmission, while the 4.176 S54 has the shortest. The S51 is in between the MR2T E153 and the V6 E153 in terms of gearing, which is why I chose it over the S54.
In order of gearing, longest to shortest (by 4th and 5th drive ratios listed respectively):
E153 3.230 1.913 1.258 0.918 0.731 Diff: 3.933 (3.610, 2.875)
S51 3.538 1.960 1.250 0.945 0.731 Diff: 3.944 (3.727, 2.883)
E53 3.583 2.045 1.333 1.028 0.820 Diff: 3.625 (3.727, 2.972)
E153 3.230 1.913 1.258 0.918 0.731 Diff: 4.285 (3.933, 3.132)
S54 3.285 1.960 1.322 1.028 0.820 Diff: 3.944 (4.054, 3.234)
S54 3.285 1.960 1.322 1.028 0.820 Diff: 4.176 (4.293, 3.424)
AFAIK, Jim King and I are the ones using the S51 coupled with the 1MZ. The ratios seem well suited during my short drive, but 1st gear is really short and almost useless. It'll definitely be of no use with a supercharged 1MZ. Acceleration in 2nd and 3rd gears is good. 4th and 5th are pretty long cruising gears and keep the engine revs low, so that's a plus. I have a 2001 S51, so I have the double synchros on 2nd and 5th, and shift feel is positively good, but mine is rebuilt.
The S54/51 shares differential with the C series tranny, so the OEM helical LSD that was available on the Spyder (2004+) drops right into an S54/51 tranny. I have one in there now
post Aug 17, 2009 - 7:45 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
Well, from my experience the s54 tranny doesn't like power over 300whp, Or possibly reving to 9k.
The s54 is tiny compared to the e153, I'd rather have the added weight (which isn't too drastic) than risk ripping gears apart.
That along with what has ben mentioned, the LSD and longer gears.
post Aug 17, 2009 - 8:18 PM
domyz
Joined Jul 29, '07
From Quebec, Canada
-E153 for double synchros (e153 has them on 2nd,3rd,5th... s54 don't have that)
without that you will blow you second gear or synchro, a common problem on 90-93s e153 who don't have that
-E153 has also an integrated oil pump to cool tranny oil and keep bearings lubrificated
-E153 clutch is much more bigger and stronger
-E153 isn't faster getting into gear....but it is shorter throw and it stays into gear firmly
-If you have 3sgte, LSD is a must and is even not enough to hold tires firmly on the ground in second gear at 15psi
This post has been edited by domyz: Aug 17, 2009 - 8:19 PM
post Aug 17, 2009 - 9:31 PM
are they hard to get?
post Aug 22, 2009 - 8:40 PM
bdub215
Joined Jul 7, '09
and here i thought the E53 was geared taller then the E153. E153's AFAIK arent hard to get. i always hear (well read) about people getting them.
90 Toyota Celica (S53) totaled R.I.P
98 Toyota Corolla (C59) 183k 117whp needs a tune
93 Lexus ES300 (E53) 120k Its a stick
95 Lexus Sc300 AutoTragic FTL
post Aug 22, 2009 - 9:42 PM
Remy
Joined Jan 25, '06
From MN
Finding one local will be hard.
This post has been edited by Remy: Aug 22, 2009 - 9:43 PM
"To Protect And To Serve The Wealthy" -POLICE
post Aug 22, 2009 - 10:18 PM
I looked around for a s54 and an e153 at car-parts.com (local junkyards). the camry e153 is actually a lot easier to find than an s54
post Aug 22, 2009 - 11:18 PM
supershannon77
Joined Jan 18, '07
From Bergen county NJ
i no jdm engine depot has a few of the camry e153 and other toyota trans that they guy is letting go for pretty cheap jims going there on monday if u want him to check anything our for u.
facebook WRC st205
post Aug 23, 2009 - 12:22 AM
QUOTE (supershannon77 @ Aug 23, 2009 - 12:18 AM) *
How much for a camry 153?
post Feb 16, 2011 - 4:29 AM
zeus83
Joined Sep 13, '08
From Kuala Lumpur, Malaysia
im still undecided whether to go E153 'n customize to fit my ST202/3SGTE or go S54 SS-III BEAMS with LSD...apparently both have LSD
from what i read here;
Option 1:
1.Get E153 Tranny
2.Get E154 tranny from ST205 GT4
3.Mix n match shifter cable, levers and axles
4.more heavy duty
Option 2:
1.Get S54 tranny from SS-III BEAMS
2.no mods required
3.is it heavy duty?
post Feb 16, 2011 - 4:47 AM
Lazurus
Joined Apr 25, '07
From Tri-cities WA
If you go with the 54/51 you can still have LSD. OEM helical LSD that was available on the Spyder (2004+) drops right into an S54/51 tranny.
http://mr2.com/forums/v6-owners-group/Toyo...ssion-poll.html
post Feb 16, 2011 - 6:08 AM
zeus83
Joined Sep 13, '08
Lazurus,
apart from the LSD, will the S54/51 be able to hold for long when mated to the 3SGTE motor?
post Feb 16, 2011 - 2:02 PM
Lazurus
Joined Apr 25, '07
From Tri-cities WA
I would contact the guys on mr2.com that are actually running that set up but I have found more than one person with 400+hp running that set up with over a year using that set up. It is the set up I am personally looking to run when I attempt to swap in the 3vz-fe.
post Feb 16, 2011 - 2:53 PM
Ted95
Joined Mar 8, '09
From Westport, MA
QUOTE (Lazurus @ Feb 16, 2011 - 2:02 PM) *
def wanna look into that and see the good word on that lol
st205 powered ss3 coupe
post Feb 20, 2011 - 2:19 PM
Definetely a good points here.. I hate to mix and match axles. tough...
Lo-Fi Version Time is now: January 10th, 2025 - 1:49 AM
