installing lowering springs with out new struts?? |
Aug 18, 2009 - 12:31 PM |
Enthusiast Joined Nov 6, '08 From locust grove, va Currently Offline Reputation: 0 (0%) |
i am looking in to lowering my car. i have decided on springs not coilovers and my question is can i install lowering springs without putting in new shocks. if yes do i need aftermarket shocks or will factory shocks suffice?
Aug 18, 2009 - 1:18 PM |
Enthusiast Joined Aug 8, '07 From United States Currently Offline Reputation: 4 (100%) |
you can run lowering springs on your stock struts. Depending on how low you go will increase the wear out speed of them.
Aug 18, 2009 - 2:47 PM |
Enthusiast Joined Nov 20, '04 From Carlisle, PA Currently Offline Reputation: 27 (100%) |
Factory struts will probably be fine for a while unless they're already worn, then you should just replace them all at once to save the hassle of doing it twice. KYB struts are pretty cheap OEM replacements, you can order front and rear for not much more than $200.
Aug 18, 2009 - 4:09 PM |
Enthusiast Joined Feb 24, '07 From Oahu, Hawaii Currently Offline Reputation: 23 (100%) |
i am looking in to lowering my car. i have decided on springs not coilovers and my question is can i install lowering springs without putting in new shocks. if yes do i need aftermarket shocks or will factory shocks suffice? yes after a months of having them you'll have a different feeling in the car, thats when you change it out for KYB GR-2, Bilstein, Konig, or Stock shocks again. Or you'll prolly have enough $$$ for coils -------------------- I don't normally drive fast, but when I do its on a curvy section of this island
Aug 18, 2009 - 4:29 PM |
KYB struts/shocks ARE oem.
Just hold off on installing until you have an extra $225ish for the KYB stuff, that way you're not doing two uninstallations and two reinstallations. -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
Aug 19, 2009 - 5:55 PM |
Moderator Joined Jun 29, '08 From Denver Currently Online Reputation: 59 (100%) |
KYB struts/shocks ARE oem. Just hold off on installing until you have an extra $225ish for the KYB stuff, that way you're not doing two uninstallations and two reinstallations. The KYB GR2's area also warrantied to be lowered up to an inch and a half, so there's a little bit of a safety net there. Otherwise, all I can say is what has already been said, that you CAN put lowering springs on factory struts, but they'll wear out a lot sooner. -------------------- "Employ your time in improving yourself by other men's writings, so that you shall gain easily what others labored hard for." -Socrates. Even Socrates told us to use the search button!
Aug 19, 2009 - 7:35 PM |
Enthusiast Joined Mar 8, '08 From Orlando, Florida Currently Offline Reputation: 14 (100%) |
Factory shocks don't last much past 60,000mi. (as i have read..)
More than likely your old shocks are due for replacement anyway, and if you put lowering springs on them you are gonna notice that you need new ones pretty soon. so.. KYB struts/shocks ARE oem. Just hold off on installing until you have an extra $225ish for the KYB stuff, that way you're not doing two uninstallations and two reinstallations. x2. This post has been edited by samir0189: Aug 19, 2009 - 7:35 PM -------------------- ◊◊◊ My F/S Thread! ◊◊◊
Aug 21, 2009 - 4:47 AM |
I dunno if kybs are OEM because I've had both and they are not the same. looks and size. I measured inside out a toyota strut mount and kyb and they are totally different, in fact they are thicker. When I put one KYB mount only in one side it raised one fender significantly higher. I used a tape measure and indeed they are different. Perhaps there is a chance that KYB is making the new ones as OEM because Toyota's new strut mounts look like KYB but for sure the original toyota mounts are indeed totally different from KYB mounts. They are OEM replacements thats for sure but thats the same as saying aftermarket.
This post has been edited by trdproven: Aug 21, 2009 - 4:50 AM -------------------- 94 Celica GT
Aug 21, 2009 - 3:26 PM |
thanks for all your help guys. i think im gonna replace them just to be safe.
Oct 18, 2009 - 12:26 AM |
Enthusiast Joined Mar 10, '08 From Socal, OC Currently Offline Reputation: 7 (100%) |
so..if i were to get these megan racing lowering springs..
http://www.upscaleautomotive.com/p-18214-m...ota-celica.aspx how long will they be good for if im using stock shocks? my car currently has about 176,4xx miles on it right now. |
Oct 18, 2009 - 1:57 AM |
most likely not very long. if they are original then running a 2 inch drop will probably kill them pretty quickly.
Oct 18, 2009 - 2:13 AM |
Not to hijack...but what's the quality like on those springs? I'm not looking for utmost comfort, so if they hold up nicely it's a good deal for half the price of Teins...
'93 MX-5 LE |
Oct 18, 2009 - 9:52 PM |
Not to hijack...but what's the quality like on those springs? I'm not looking for utmost comfort, so if they hold up nicely it's a good deal for half the price of Teins... i don't have them, but i remember reading through the forums that they do provide a nice drop and nice ride. and the guy had KYB shocks too. i think it's pretty worth it from what i know. haha, the price is amazing..aint it? |
Oct 18, 2009 - 9:54 PM |
Half the price is most definitely amazing.
'93 MX-5 LE |
Lo-Fi Version | Time is now: November 26th, 2024 - 10:17 PM |
