> how bad is it
post Aug 19, 2009 - 1:06 AM
spy00005
Joined May 15, '09
From yonkers, NY
well was painting my rims (refurbishing them whatever) i did them 2 at a time first front 2 then rear 2. front 2 everything was fine. but i took of the rear and came back like 10 min later an the car was on the floor. i always use those jack stands. the car had apparently rolled back a lil and the jack fell back. i didn't see any real damage can't tell yet for sure but the rear disk might be a lil roughed up an the metal around it is bent. the metal was easy 2 bend back. its stick but i always leave it in 1st and the e brake was all the way up. it fell would say about a foot to a foot and a half. wat type of damage should i be looking for. by the way i put a big rock behind the front wheel but seems it didn't help. will it be fine what do i look for. i know i know im so stupid but Ive worked on my car for about 2 years all types of things nothing like this has ever happened before.
these are basically the jack stands i used
*Thing i want for my car(i wish i had money)*
-full gt4 front end conversion (DONE :) JUST NEEDS PAINT(next on to do list) -new seats all around
-riser blocks -fog lights -new radio and speakers all around
-full bodykit splitters and sideskirts to go with conversion (just needs fitting and painting)
-nice rims (Got TC rims and painted them white)
-light blue tint (next step will do this right after i get my paint job)
WTB Reasonably priced
Projectors just Lows
post Aug 19, 2009 - 2:12 PM
Hezz
Joined Jul 25, '09
From Basin City, WA
You are probably fine, rotors are incredibly tough. Put the wheels on and drive it, if the brakes make noise or shake, it's time for new rotors.
post Aug 19, 2009 - 4:00 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
If you were in first your car shouldn't have rolled back - especially if you had the rear of the car up in the air. If anything it should have rolled forward, due to the E-brake pulled (no use if your rear end is airborn!), being in first gear, the rear up higher in the air, and a rock behind the front wheels (won't help if it rolls forward)
So with that said - are you SURE it didn't roll forward, because unless you were parked up a slope, it couldn't have rolled backwards on it's own.
**** Photobucket
post Aug 19, 2009 - 9:38 PM
spy00005
Joined May 15, '09
From yonkers, NY
WELL its driving fine. sure it rolled back (im afraid that some one might have bumped into it) i can tell cuz of the marks left on the street you see the drag marks it rolled back.
Lo-Fi Version Time is now: November 29th, 2024 - 8:44 AM
