6G ABS, is it reliable?, with or without ABS |
Aug 20, 2009 - 2:51 AM |
Enthusiast Joined Sep 13, '08 From Kuala Lumpur, Malaysia Currently Offline Reputation: 0 (0%) |
Hi all,
I just got my ST205 half cut and it came with ABS. The question is, is it better to go ahead and install it on my ST202? any reliability problems, brakes jamming...etc thx |
Aug 20, 2009 - 4:51 AM |
Enthusiast Joined Feb 24, '07 From Oahu, Hawaii Currently Offline Reputation: 23 (100%) |
i dunno but you dont have the rear abs things so i would say its useless???
do you really need abs? -------------------- I don't normally drive fast, but when I do its on a curvy section of this island
Aug 20, 2009 - 5:00 AM |
Enthusiast Joined Dec 15, '02 From Tasmania(Australia) Currently Offline Reputation: 0 (0%) |
if you dont have abs in the car then it would be a massive job to install it ( you cant just have abs in the front)
ill take the front sensors off you if you dont want them. -------------------- ST205 Group A Rallye GT-Four, #61 of 77............600hp GT3582r
GRX133 Toyota Mark X 350s |
Aug 20, 2009 - 10:25 AM |
i dunno but you dont have the rear abs things so i would say its useless??? do you really need abs? The H/C came with the rear rotors and calipers + ABS Sensors, i just have to modify the solid metal hose going to the rear... do i need it? i would say yes, it rains alot down here My concern was its reliability... if you dont have abs in the car then it would be a massive job to install it ( you cant just have abs in the front) ill take the front sensors off you if you dont want them. installation is no issue, reliability and effectiveness are...thats why i need feedback from the dudes whom are using it This post has been edited by zeus83: Aug 21, 2009 - 12:54 AM |
Aug 20, 2009 - 1:45 PM |
Enthusiast Joined Feb 11, '09 From Geleen The Netherlands Currently Offline Reputation: 0 (0%) |
Abs on a celica is very reliable i have it on my ST.
Be careful if you want to take the sensors out of the hub, i wrecked mine when i replaced the wheel bearing and they are very expensive parts. |
Aug 20, 2009 - 5:25 PM |
i dunno but you dont have the rear abs things so i would say its useless??? do you really need abs? installation is no issue, reliability and effectiveness is...thats why i need feedback from the dudes whom are using it in that case ide say yeah if you can be bothered going through the massive task of installing the stepper motor and running all the hard lines, and wiring in the abs ecu. its very effective and relaible, and if anyone tells you they can stop better without abs then with they are full of ****. I duno if the 202's have the same abs units as the 205s (when they are factory abs i mean) The 205 abs has g sensors in the stepper motor that can diffrentiate between cornering and straight line breaking and hence give the correct ammount of braking force to the correct wheels at the correct time. Toyota called it "sports abs" and was pretty advanced for 1994. -------------------- ST205 Group A Rallye GT-Four, #61 of 77............600hp GT3582r
Aug 21, 2009 - 12:43 AM |
i dunno but you dont have the rear abs things so i would say its useless??? do you really need abs? installation is no issue, reliability and effectiveness is...thats why i need feedback from the dudes whom are using it in that case ide say yeah if you can be bothered going through the massive task of installing the stepper motor and running all the hard lines, and wiring in the abs ecu. its very effective and relaible, and if anyone tells you they can stop better without abs then with they are full of ****. I duno if the 202's have the same abs units as the 205s (when they are factory abs i mean) The 205 abs has g sensors in the stepper motor that can diffrentiate between cornering and straight line breaking and hence give the correct ammount of braking force to the correct wheels at the correct time. Toyota called it "sports abs" and was pretty advanced for 1994. Great Info dude...THX! |
Nov 12, 2013 - 12:21 AM |
revival from the grave. but concerning the different in gt4 and celica that came with superstut and abs.
American ABS brake system for ST204 have completely different part #. whats the benefit of the sport ABS found on Japanese celicas -------------------- Group buy to replicate Narrow E series transaxle parts
Nov 12, 2013 - 1:48 AM |
Enthusiast Joined Apr 16, '10 From Poland Currently Offline Reputation: 0 (0%) |
Isnt this called TRC? I know Japan spec Celicas have TRC and TRC OFF light in gauge cluster. I dont think ABS is able to help cornering.
From wiki: QUOTE Typically, traction control systems share the electro-hydraulic brake actuator (but does not use the conventional master cylinder and servo), and wheel speed sensors with ABS.
This post has been edited by Makabra: Nov 12, 2013 - 1:54 AM |
Nov 12, 2013 - 2:24 AM |
Enthusiast Joined Dec 16, '11 From The Netherlands Currently Offline Reputation: 5 (100%) |
Also, there was a update on the ABS unit when the facelift models were launched...can anyone confirm this ?
Nov 12, 2013 - 6:50 PM |
I've read about the ABS control system from the GT-Four using additional input from accelerometers, and not only wheel speed sensor input.
I'm guessing with the accelerometers, the control system takes corner weight due to weight transfer into account so the pumping frequency of the abs can vary based on how loaded each tire is for better performance. just a guess. -------------------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- |
Lo-Fi Version | Time is now: November 26th, 2024 - 2:46 PM |
