> Do you want to install Glow Gauges?, If you want to know how to install glow gauges, read this topic!
post Aug 20, 2009 - 6:06 PM
Dennisj1
Joined Oct 6, '08
From Netherland antilles
Hey guys,
I have replaced my original gauges with glowing gauges and I just wanted to share my experiance with the ones that also might be interested on changing their gauges!
I'm not an profeshonal on this so everything you guys do is on your own!
Here is an picture of how they turned out.
http://i763.photobucket.com/albums/xx273/D...j1/IMG_2617.jpg
Nice ha??!!!!
Ok, for the installation.
1. Remove the instrument cluster. removing the two screws located in the top portion of the cowl, and gently pulling on the bottom portion of the instrument cowl. Then remove the remaioning 4 screws holding down the actual cluster.
2. Carefully remove the 3 connectors but be carefull not to damage anything!
http://i763.photobucket.com/albums/xx273/D...j1/IMG_2593.jpg
3. When you get the cluster out, remove the front clear face shield.
http://i763.photobucket.com/albums/xx273/D...j1/IMG_2595.jpg
4. Remove the black face that will allow you to access the gauges.
http://i763.photobucket.com/albums/xx273/D...j1/IMG_2596.jpg
5. DO NOT REMOVE ANY OF THE NEEDLES
6. DO NOT REMOVE THE PLASTIC PLATE WHERE THE NUMBERS AND SYMBOLS ARE.
7. DO NOT MOVE THE FUEL NEEDLE
8. DO NOT BEND THE NEEDLES
9. ONLY MOVE THE NEEDLES CLOCKWISE OR COUNTER CLOCK WISE LIKE THEY ARE DESIGNED TO DO
10. The glow gauges comes with their own wiring and a on/off switch.
http://i763.photobucket.com/albums/xx273/D...j1/IMG_2594.jpg
11. Carefully slide the new gauges on top of the original ones. First make shure the needle goes through, then make it fit perfictly.
http://i763.photobucket.com/albums/xx273/D...j1/IMG_2597.jpg
12. for them to fot perfict, you can glue them on top of the original ones. but note that the original ones might get damaged by the glue!
13. Make shure that the open door icon on the RPM glow gauge is presicely on top of the original icon.
http://i763.photobucket.com/albums/xx273/D...j1/IMG_2598.jpg
14. for the air bagg side icons and the engine side icons do the same as step 13. or leave the original out and put only the new ones in.
15. note that the new gauges does ton come with the ABS, Cruise control and Over Drive icons! (don't know yet how to make them visible)
http://i763.photobucket.com/albums/xx273/D...j1/IMG_2599.jpg
16. MAKE SHURE THAT NOTHING INTERFIERS WITH THE NEEDLES EXPESHALLY WHEN PUTING EVERYTHING BACK TOGETHER, BECAUSE THEY WILL NOT WORK PROPERLY!! TAKE YOUR TIME TO DO IT RIGHT!
17. When putting the black face back on, check if it presses to much on the wires of the glow gauges. if so, customize it so it presses less on the wires.
http://i763.photobucket.com/albums/xx273/D...j1/IMG_2600.jpg
18. Put the cleare face shield back on.
http://i763.photobucket.com/albums/xx273/D...j1/IMG_2601.jpg
19. Connect the plus and the negative wires of the glow gauges to your low beam switch.
20. install the cluster back in you car.
http://i763.photobucket.com/albums/xx273/D...j1/IMG_2606.jpg
21. Connect the on and off switch where you desire.
22. turn your low beam on, and then hit the on/off switch!!!!
23. BAMMMMM!!!!! Let there be light!!!
http://i763.photobucket.com/albums/xx273/D...j1/IMG_2607.jpg
http://i763.photobucket.com/albums/xx273/D...j1/IMG_2608.jpg
http://i763.photobucket.com/albums/xx273/D...j1/IMG_2609.jpg
http://i763.photobucket.com/albums/xx273/D.../IMG_2616-1.jpg
Hope there is enough information for you guys, it been a pleasure to finally put some of my experiance on this forum.
And I bought the gauges on ebay!!!! (Search for celica 94-99 glow gauges)
post Aug 20, 2009 - 7:38 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
Reposted for ease of viewing and readability
QUOTE (Dennisj1 @ Aug 20, 2009 - 4:06 PM) *
Hey guys,
I have replaced my original gauges with glowing gauges and I just wanted to share my experience with the ones that also might be interested on changing their gauges!
I'm not an professional on this so everything you guys do is on your own!
Nice ha??!!!!
1. Remove the instrument cluster. removing the two screws located in the top portion of the cowl, and gently pulling on the bottom portion of the instrument cowl. Then remove the remaining 4 screws holding down the actual cluster.
2. Carefully remove the 3 connectors but be careful not to damage anything!
11. Carefully slide the new gauges on top of the original ones. First make sure the needle goes through, then make it fit perfectly.
12. for them to fit perfect, you can glue them on top of the original ones. but note that the original ones might get damaged by the glue!
13. Make sure that the open door icon on the RPM glow gauge is precisely on top of the original icon.
14. for the air bag side icons and the engine side icons do the same as step 13. or leave the original out and put only the new ones in.
16. MAKE SURE THAT NOTHING INTERFERES WITH THE NEEDLES ESPECIALLY WHEN PUTTING EVERYTHING BACK TOGETHER, BECAUSE THEY WILL NOT WORK PROPERLY!! TAKE YOUR TIME TO DO IT RIGHT!
18. Put the clear face shield back on.
Hope there is enough information for you guys, it been a pleasure to finally put some of my experience on this forum.
**** Photobucket
post Aug 20, 2009 - 8:01 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
So, I have this same set, and really, the "switch" is kinda annoying. I have mine tapped into the gauge lights (so when the car is on, and the i turn on the parking/gauge lights, the gauge over lay can be turned on. Anyone ever just solder some wire between the two contacts of the switch (before they mate up to the actual switch), Im guessing that this should create a constant circuit so when the lights go on, so does the overlay.
post Aug 20, 2009 - 8:02 PM
conus00
Joined Jul 10, '08
From Tampa, FL
Now you just need to paint needles red, kinda hard to read the gauges as it is...
Good write-up, though.
'94 ST
post Aug 20, 2009 - 10:35 PM
Dennisj1
Joined Oct 6, '08
Hey spider 77,
Is best not no solder the two wires of the on/off switch together, beqause the glow gauges came with a small circuit inside a black box. This circuit needs to get a signal every time that 12 volt is applied to it (through your switch that turs on the parking lights) to be able to turn the gauges on.
Thats why when you turn the gauges off, and back on, they wont light up until you press the on/off switch.
Every thing is managed by the circuit in the black box.
I find the on/off swich ugly two!!! I wanted to put a small fotocell that will turn the gauge on when you are in a dark place. But when I found out that you need to press the on/off switch i changed my mind!
Do you have some pics of how your gauges look like?
post Aug 20, 2009 - 11:28 PM
forkee
Joined Nov 13, '02
From So Cal
nice. i remember doing a writeup on this way back ago, back in the geocities days lol. mine is tapped into the fusebox for the gauges so that they only go on when i turn the instrument panel on. its a simple $3 part from pep boys. no soldiering required.
post Sep 29, 2009 - 11:36 AM
sunwukongg
Joined Mar 10, '08
From Socal, OC
just recently ordered these on ebay. can't wait to get em installed. hope i dont mess up kindasad.gif
post Sep 29, 2009 - 7:42 PM
Dennisj1
Joined Oct 6, '08
Allright Men,
Good luck!!! Remember to take your time, make shure nothing disturbes the Needles...
post Sep 29, 2009 - 8:03 PM
sunwukongg
Joined Mar 10, '08
From Socal, OC
QUOTE (Dennisj1 @ Sep 29, 2009 - 7:42 PM) *
Allright Men,
how long did it take you to do this whole thing? and "12. for them to fit perfect, you can glue them on top of the original ones. but note that the original ones might get damaged by the glue!" did you use glue?
post Oct 1, 2009 - 6:07 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
QUOTE (sunwukongg @ Sep 29, 2009 - 6:03 PM) *
Allright Men,
Use double stick tape.
post Oct 2, 2009 - 10:56 AM
Dennisj1
Joined Oct 6, '08
QUOTE (GriffGirl @ Oct 1, 2009 - 6:07 PM) *
Allright Men,
I used Glue (crazy glue), but if your hands are dirty and the glue gets on your hand, you might get the gauges dirty if you touch them with your hand. That is a disadvantage when using crazy glue.
Doubleside tape may also work!!!! but remember ta the new gauges does not have to interfeer with the needles! the doubleside tape needs to be thin so that the new gauges can sit as close as possible on the old ones.
It took me about half an hour to install them, but the next day I had to take everything appart because the needles where not working properly.
Let us know how it went!
post Oct 7, 2009 - 10:02 PM
sunwukongg
Joined Mar 10, '08
From Socal, OC
QUOTE (Dennisj1 @ Oct 2, 2009 - 11:56 AM) *
my glow gauge installation..was a mess...it's all good now and i love it. only problem is my RPM gauge isn't working, idk why kindasad.gif i think somethings wrong with the green circuit board film thingy on the back of the cluster..it looks work or something..i went to a toyotas dealer to try and buy a new circuit board, but i hear that it was $90, not only that..but its now discontinued, so i cant get one until someone parts it out kindasad.gif
post Oct 8, 2009 - 7:06 AM
Dennisj1
Joined Oct 6, '08
Congrats!
My RPM gets some times stuck too at around 7000 RPMs. But since I usualy don't drive fast I don't reach 7000 RPM that often laugh.gif
You shure nothing is interfering your RPM needle?
How long did it take you and what did you use, glue or tape?
Do you have pictures?????
post Jan 17, 2010 - 5:22 AM
Slick
Joined Jan 10, '06
From Mozambique, Africa
Nice write up. Where did you get the gauges? Are there any available for JDM celicas?
post Jan 17, 2010 - 9:29 AM
Dennisj1
Joined Oct 6, '08
THX Slick!!!!!
I don't know if there is one for JDM.
I got my on ebay!
post Jan 17, 2010 - 4:57 PM
terbear4god4life
Joined Oct 10, '08
From sweet home, OR
i got mine always on so if i go into a tunnel or something they glow laugh.gif
"she can polish my strut bar anytime As long as her blow-off valve's in good order"
post Jan 17, 2010 - 8:05 PM
legalkid86
Joined Dec 14, '08
From RGV, Texas
hey does anyone know if we need to have new leds installed or will the actual guages light on their on sorry might be a dumb question but yeah can anyone answer me..
wAkE uP, u'Ll sLeEp WhEn U DiE.....
post Jan 18, 2010 - 5:29 PM
Dennisj1
Joined Oct 6, '08
No, you won't be needing LED's. The gauges come with the lights build in.
The only "old" lights that will remain visible are the ones of the needles.
So if you want the needles to show brighter or another color, you can replace those bulbs with LED's or a different color.
But, these gauges are so bright and cool that you won't even pay attention to the color of the needles!
post Jan 22, 2010 - 12:14 AM
GriffGirl
Joined Feb 7, '07
You can also power these by connecting the positive lead to the accessory lead off an aftermarket stereo; typically it's an orange wire connected to nothing. I power mine this way, so they come on when I turn on my parking lights. I grounded it by adding one of those little circle-ended terminal connectors and screwing it in where the radio bracket bolts in. I've had it for probably a year and a half and have never had a problem with it.
post Jun 15, 2010 - 10:07 PM
96stgreendemon
Joined Oct 7, '09
From Northern kentucky
just curious i just got these today and how exactly do you get teh fuel and temp on witough moving the fuel gage? help
2001 Solar yellow Lexus IS300
Lo-Fi Version Time is now: November 23rd, 2024 - 5:41 PM
