> want to turbo my 7afe. need suggestions and suchh., who has what up there sleeve?
post Aug 21, 2009 - 9:16 PM
TerBeau
Joined Nov 25, '08
From dillsburg pennsylvania united states
soo i just bought a 96 celica with out a motor. i kinda want the 7afe motor and just turbo that. i found the motorr for 400 bucks 80000 miles on it. 4afe turbo manifold will work? t25 turbo gunna work fine with with the 7afe and mainfold? heeellppppp
This post has been edited by TerBeau: Aug 22, 2009 - 9:50 PM
those with golf balls golf
those with real balls race
post Aug 21, 2009 - 9:24 PM
match220
Joined May 13, '06
From Kaimuki, HI
did it originally have a 7a motor in it? Or was it a 5s? I'm pretty sure the motor mounts are completely different between the two engines. I've heard the frames are different, but I've never seen it for myself.
-Jay
95 GT conv. project car: Manual, Gen III 3sgte, JN pisons, Eagle rods, overbore, crank knife-edged, crank scraper, ARP head/main/flywheel, Autronic EMS, Haltech Dual Wideband O2 controller, Audi 1.8T individual coils, FMIC and SSQV BOV, 3" downpipe, 3" ultra-high-flow cat, 2.5" Borla muffler, +other
01 S2000: FMIC, Haltech EMS, Haltech wideband, 570cc inj, forged pistons/rods, sleeved block, 5 angle valve job, ported and polished
02 R6, all stock, except for braided stainless brake lines, frame sliders, and adjustable brake/clutch leve
post Aug 21, 2009 - 9:28 PM
TerBeau
Joined Nov 25, '08
QUOTE (match220 @ Aug 21, 2009 - 10:24 PM) *
the vin reads the 7afe with egr so im assuming it had a 7afe in it before
post Aug 22, 2009 - 3:20 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
find a 4A-GZE and put that in
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Aug 22, 2009 - 2:54 PM
TerBeau
Joined Nov 25, '08
QUOTE (Smaay @ Aug 22, 2009 - 3:20 AM) *
does that use the same computer and harness?
post Aug 22, 2009 - 4:48 PM
Remy
Joined Jan 25, '06
From MN
You should start here = http://www.6gc.net/forums/index.php?showtopic=1311
"To Protect And To Serve The Wealthy" -POLICE
post Aug 22, 2009 - 8:25 PM
CelicaST_CALI
Joined Feb 28, '07
7afte-2500$ 150-200hp
4agze-2500$ 160 hp supercharged
my price for the 4agze is off probably but to bad...u can use a honda b16 manifold or find a 7afte manifold...post up a wtb if your serious...
BANNED. for life, you moron.
post Aug 22, 2009 - 9:39 PM
TerBeau
Joined Nov 25, '08
QUOTE (CelicaST_CALI @ Aug 22, 2009 - 9:25 PM) *
i appreciate that. but i found out that a 4afe and a 7afe have the same part number for the gasket set meaning that a 4afe turbo manifold will work on my 7afe motor, and a t25 turbo will work. correct me if im wrong. i called auto zone and got the part numbers and compared them and they indeed are tha same. now my other concerns. i have a mandrel pipe bender that my dad got for at his shop so we are going to fabricate all my piping. but him and i are going to tig weld the pipes together and not use the sleeves to put them together. is this bad? and all i really need to get is that manifold, the intercooler, the oil line for the sending and returning, but one other thing what if the turbo is water cooled on top of oil cooled? is that only if the turbo has ball bearings?
post Aug 22, 2009 - 10:02 PM
CelicaST_CALI
Joined Feb 28, '07
If its water cooled u have to run coolant lines and idk how that would be.What piping are u talking about?Intercooler piping that ur gonna bend and fab?Welding the pipes together is perfectly fine to do,as long as the welds are strong....
post Aug 22, 2009 - 10:16 PM
TerBeau
Joined Nov 25, '08
QUOTE (CelicaST_CALI @ Aug 22, 2009 - 11:02 PM) *
yes the intercooler pipes. and yes i understand they have to be strong welds i really would hate to sit along side the highway cuz i did a boo boo lol. but im really curious to see if the 4afe manifold will acually fit. its not long its short soo i guess ill find out here soon.
post Aug 22, 2009 - 10:23 PM
TerBeau
Joined Nov 25, '08
your 100% that a b16 manifold bolts on?
post Aug 23, 2009 - 12:13 PM
CelicaST_CALI
Joined Feb 28, '07
http://www.6gc.net/forums/index.php?showtopic=27539&hl=
http://www.6gc.net/forums/index.php?showtopic=30398&hl=
http://www.6gc.net/forums/index.php?showto...4390&hl=b16
QUOTE (playr158 @ Mar 1, 2006 - 9:01 PM) *
its in teh STICKIES wink.gif "7afe maps and ect."
you have to cut the manifold's flange off (the engine side)
and weld on a 7afe flange (runner extension might be needed)
flanges available from jgstools.com/turbo
also you need to reinforce the welds on that manifold as they are know to crack and a brace (if it doesn't come with one) should be welded from flange to flange to aid in support
This post has been edited by CelicaST_CALI: Aug 23, 2009 - 12:14 PM
post Aug 23, 2009 - 11:16 PM
TerBeau
Joined Nov 25, '08
QUOTE (CelicaST_CALI @ Aug 23, 2009 - 1:13 PM) *
ha ok i got ya.. well i think ilkl stick with the 4afe manifold. would i need to put a differnt head on it, injectors, gasket, so forth? if ill be running like 8 psi? and my clutch will i need to upgrade or can i stick to my stock one? lol so many questions!!! and is and internal waste gate better to use than lets say a external bov?
post Aug 24, 2009 - 2:47 PM
OOBE
Joined Aug 30, '02
From San Juan, PR
I say get a 4A-GZE and turbocharge it later down the road. The 7A-FE takes too much money to run it reliably. I'm sticking with mine because it would be lost money to change engine since I've spent so much on little stuff here and there. I'm currently repairing it. Second time it breaks a piston, and it's a really small crack. The rods are fine still. I don't think they're as weak as people say they are or as they look. I've overboosted over 20 PSI recently and all pistons have survived and the rods are fine. The broken piston didn't break more than what it was, and I'm sure it broke because of detonation and not boost level.
post Aug 24, 2009 - 3:16 PM
TerBeau
Joined Nov 25, '08
QUOTE (OOBE @ Aug 24, 2009 - 3:47 PM) *
well what makes that motor so much more special. i was on a corolla foruma nd they were all about changing to a 7afe? and to my knowlege the 4agze is a 1.6 ltr out of a corolla? why is this one better? doe sit have better compression and with stand more intense(MOMENTS)? or something? would it use the same ecu and use the same wiring harness as the 7afe?
post Aug 24, 2009 - 3:38 PM
OOBE
Joined Aug 30, '02
From San Juan, PR
The 4A-GZE is a performance-oriented engine. It's stronger, even if it has less torque than a turbocharged 7A-FE. No, ECU and wiring needs to be changed. Totally different engines other than being in the same family and bolting right up to the ST's engine bay.
post Aug 24, 2009 - 5:05 PM
nik
Joined Sep 30, '02
and you can use your c52 tranny along with the axels that your cars has now saving you money
post Aug 24, 2009 - 6:17 PM
TerBeau
Joined Nov 25, '08
ok sounds reasonable.. now what year corolla might i find this motor in? im really interested to. and will it stand more boost? or no.. also i replaced my other celica motor one before and kep the head and it looks diff than the one i have in the car now. it has like cylinders for the arms to rock on. it has sleeves on the outer ring.... sound familiar
post Aug 24, 2009 - 6:50 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
You can look for a AW11 4A-GZE (MKI MR2) or get a JDM AE101 4A-GZE which is newer, distributorless ignition system, etc.
The added benefit is that the GZE comes with forged internals (because it's supercharged) so you're basically set for internals. As far as wastegate and bov, you're getting two seperate items mixed up. A wastegate controls exhaust flow to the turbo. A blow off valve redirects compressed air either into the atmosphere (VTA) or recirculates it back into the intake.
**** Photobucket
post Aug 24, 2009 - 7:04 PM
TerBeau
Joined Nov 25, '08
QUOTE (95CelicaST @ Aug 24, 2009 - 7:50 PM) *
wow haha ii did get them mixed up guess ur right sorry bout that... but how much do these motors cost im kinda putting a budget to myself cuz some of us kinda know how most women can be wen in a relationship. lol. but are these motors popular to find at local junckyards?
Lo-Fi Version Time is now: November 25th, 2024 - 10:13 AM
