want to turbo my 7afe. need suggestions and suchh., who has what up there sleeve? |
Aug 24, 2009 - 9:35 PM |
Enthusiast Joined Nov 25, '08 From dillsburg pennsylvania united states Currently Offline Reputation: 12 (100%) |
as stated on feasible and non feasible
(This engine will swap directly into any Celica with a 7A-FE(USDM ST) because both engines are A-series engines. This engine will bolt right up to your stock USDM ST(AT200) transmission, though the stock tranny may not be able to handle the 4A-GZE's boost very well. It's advised that you simply use the tranny that comes with the 4A-GZE engine.) they dont thing that the stock 7a tranny can handle boost.. what do these usually put out in psi? -------------------- those with golf balls golf those with real balls race |
Aug 24, 2009 - 11:44 PM |
AE101 GZE is 12psi stock
AE92 is 8-9psi stock -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
Aug 25, 2009 - 12:14 PM |
AE101 GZE is 12psi stock AE92 is 8-9psi stock ok and what is the diff between the 4age and the 4afe? i looked every were at local junk yards and they dont have a gts motor anywere -------------------- those with golf balls golf those with real balls race |
Oct 18, 2009 - 11:34 AM |
Enthusiast Joined Oct 16, '09 From Ohio Currently Offline Reputation: 0 (0%) |
4a-ge are the 20v 4cyl engines. They have individual throttle bodies and have 4 extra valves. There heads are better than our 7a-fe head flow wise BUT there blocks are NOT boost capatible. There internals are equipped to handle boost. But the 7afe block are stronger than the 4age.
4afe on the other hand is a 1.6 liter engine that came carollas i think? base horsepower is like 105. its pretty ****ty even compared to our 7a-fe which is 1.8l. |
Lo-Fi Version | Time is now: November 25th, 2024 - 10:51 AM |
