Enthusiast ![]() ![]() Joined Jul 15, '08 From Norway Currently Offline Reputation: 5 (100%) ![]() |
Hello!
I have a AT200 with stock suspension. I have recently got some big wheels (215/35R18 (ET35)) and my ride is a bit high. Especially in the front. Pictures: ![]() ![]() ![]() ![]() ![]() As you see, the front is a lot higher than the back, which look a bit.. Weird.. I did some measurements (not perfectly accurate, though): - Front space between fender and the alu wheel: 11,3cm - Back space between fender and the alu wheel: 9,4cm So, I want to drop my car a bit. Not too much, since I want to use this drop on the winter too. (A lot of snow here in Norway in the winter, you know) I want a look which is visible lower in the front, which makes an agressive look. What do you suggest to drop? (On both back and front) ANY answer will be greatly appreciated! ![]() |
Enthusiast ![]() Joined Jun 9, '09 From Norway Currently Offline Reputation: 1 (100%) ![]() |
considering you are in norway you should go to eiker.com. Its were i bought my lowering springs
the springs are on this page -------------------- Angry Norwegian Anchovies
Enthusiast Joined Mar 17, '08 From Norway Currently Offline Reputation: 1 (100%) ![]() |
considering you are in norway you should go to eiker.com. Its were i bought my lowering springs the springs are on this page Agreed, 40/40mm on your car was niiiiiiiiiiiiiiiiiiiiiiiice ![]() ![]() -------------------- --------------------
Angry Norwegian Anchovies |
considering you are in norway you should go to eiker.com. Its were i bought my lowering springs the springs are on this page Agreed, 40/40mm on your car was niiiiiiiiiiiiiiiiiiiiiiiice ![]() ![]() thank you ![]() -------------------- Angry Norwegian Anchovies
But, with 40 on both rear and front, will still make the front look higher?
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 24, '07 From Oahu, Hawaii Currently Offline Reputation: 23 (100%) ![]() |
go lower!!!!!
-------------------- I don't normally drive fast, but when I do its on a curvy section of this island
![]() Enthusiast ![]() ![]() Joined Dec 17, '02 From UK Currently Offline Reputation: 0 (0%) ![]() |
It looks worse in that pic because you've turned the front wheels out, but does seem higher yeah. If you can get Spax springs in your country, go for them as they tend to lower more at the front than the back which would even it out
![]() ![]() This post has been edited by Tony-94: Aug 23, 2009 - 7:48 AM -------------------- Facelift bumper-foglights-clear indicators, clear side repeaters, 16in O.Z alloys, stainless steel grill. JDM facelift tail lights. clear sidelights. Retro-fit A/C conversion. APEX performance springs. Remus exhaust. K&N performance filter. KYB excel G shocks.
Hyundai coupe Mk 3 (US Tiburon) leather seats. Gen 7 s/wheel. SR black vinyl door cards. Late spec spoiler-less tailgate with 3rd brake light. |
Lo-Fi Version | Time is now: April 22nd, 2025 - 1:13 AM |
