Your experience with LED bulbs? |
Aug 22, 2009 - 10:51 PM |
I've tried a few cheap led replacement 194 bulbs, only to have them burn out after just a few days of use.
Anyone have better luck with theirs? Any specific brands to stick with? Im looking for something that will work well for the rear license plate, not to illuminate the gauge cluster. This post has been edited by lagos: Aug 22, 2009 - 11:05 PM -------------------- 15PSI - 30MPG - Megasquirt Tuned
Aug 23, 2009 - 6:37 AM |
Enthusiast Joined Jun 12, '09 From Hull, England Currently Offline Reputation: 0 (0%) |
i've had nothing but problems, they are cheap you end up paying more for P+P then you do for the bulbs and they never seem to last the 100,000's of hours quoted in their guarantee but who is going to waste time sending back defective bulbs?
Aug 23, 2009 - 9:02 AM |
Enthusiast Joined Mar 23, '08 From Denmark Currently Offline Reputation: 10 (100%) |
http://stores.shop.ebay.co.uk/EnKMall__W0QQ_armrsZ1
Use this seller. Bought from him about 10 times know and they work perfectly -------------------- [font=CELICA FOREVER][/font]
Aug 23, 2009 - 9:22 AM |
as long as you dont mess with the dimmer on the ones hooked up to the interior lights they should last a while.
i dimmed my clusters on a extra set to see what happened and burned them out -------------------- 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
Aug 23, 2009 - 11:33 AM |
LED are design for an specific Voltage, if they are not getting that voltage they'll die.
even cheap ones will last as long as they get the right voltage, that means, no messing with the dimmer switch and making sure you have good grounds. -------------------- |
Aug 23, 2009 - 11:37 AM |
Enthusiast Joined Mar 20, '07 From Bakersfield, CA Currently Offline Reputation: 10 (100%) |
^^ I agree with the man above.... No, not GOD! With Culp! LOL
-------------------- 91 MR2 Turbo SW20, 92 MR2 Turbo SW20, 95 Celica GT ST204
Aug 23, 2009 - 12:40 PM |
Enthusiast Joined Feb 24, '07 From Oahu, Hawaii Currently Offline Reputation: 23 (100%) |
what kind of leds did you get?? invert cone style? 360 3mm refractor, SMD chip type, simple 5mm led?? I noticed when i bought 194 from my friends shop ($10 a pop) they were really good for awhile, until my tach bulb started dimming more that the others. asked my friend, shop owner, he said my dimmer switch might be on full crank and its reacting like how led turn signals would. Ahhh frick its too early in the morning for me forgot the exact words he said If your gonna just do your plate lights you prolly want something shooting down, not forward, cuz i used diff. types and the 360` type works best.
-------------------- I don't normally drive fast, but when I do its on a curvy section of this island
Aug 23, 2009 - 12:56 PM |
LED are design for an specific Voltage, if they are not getting that voltage they'll die. even cheap ones will last as long as they get the right voltage, that means, no messing with the dimmer switch and making sure you have good grounds. You are correct, however there is one problem. Say for example we are talking about the gauge cluster. The power at the cluster alone can range anywhere from 14v all the way down to 11v depending on how many after market accessories your car has, as well as your alternators output. Even if you never touch the dimmer (im planning to by pass mine in general) there is a wide range of voltage that the bulbs will see naturally. The really cheap ones tend to be very sensitive to these normal changes in voltage and quickly blow out. This is at least my experience with cheap LEDs that I've tried before. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Aug 23, 2009 - 1:00 PM |
Im thinking about trying these for plate bulbs.. 12leds in one.
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...RK%3AMEWAX%3AIT -------------------- 15PSI - 30MPG - Megasquirt Tuned
Aug 23, 2009 - 9:55 PM |
i thought you fixed the problem so that the voltage doesnt fluctuate as much due to your electronics
Aug 23, 2009 - 10:11 PM |
Enthusiast Joined Mar 8, '08 From Orlando, Florida Currently Offline Reputation: 14 (100%) |
Mannnn. I was just gonna get some white leds for my gauge cluster. crap!!!!!!!!
On second thought, these people say the dimmer switch works with theirs?! http://www.superbrightleds.com/carbulb-notes.htm This post has been edited by samir0189: Aug 23, 2009 - 10:25 PM -------------------- ◊◊◊ My F/S Thread! ◊◊◊
Aug 23, 2009 - 11:04 PM |
Enthusiast Joined Mar 22, '07 From Murphy, TX Currently Offline Reputation: 5 (100%) |
Mannnn. I was just gonna get some white leds for my gauge cluster. crap!!!!!!!! On second thought, these people say the dimmer switch works with theirs?! http://www.superbrightleds.com/carbulb-notes.htm I just bought a bunch from them for the gauges - so we'll see how well they work when I get them. This post has been edited by 2bcelica: Aug 23, 2009 - 11:04 PM |
Aug 23, 2009 - 11:43 PM |
Mannnn. I was just gonna get some white leds for my gauge cluster. crap!!!!!!!! On second thought, these people say the dimmer switch works with theirs?! http://www.superbrightleds.com/carbulb-notes.htm I just bought a bunch from them for the gauges - so we'll see how well they work when I get them. please let me know! -------------------- ◊◊◊ My F/S Thread! ◊◊◊
Aug 24, 2009 - 12:32 AM |
i thought you fixed the problem so that the voltage doesnt fluctuate as much due to your electronics Yes I did, but you have to remember that normally your voltage will not always be the same. When you start the car up cold, you normally see 14.4v. Then it settles to around 13.7. Then when your roll your windows down, or your fans come on, it dips down to around 12.7. This is all normal, but I think its what blows out the cheap LEDs. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Aug 24, 2009 - 12:38 AM |
Mannnn. I was just gonna get some white leds for my gauge cluster. crap!!!!!!!! On second thought, these people say the dimmer switch works with theirs?! http://www.superbrightleds.com/carbulb-notes.htm Yeah someone else just recommended them to me and claims they dim just fine with no problems. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Aug 24, 2009 - 1:49 AM |
here is an interesting solution i found for those having issues with even coverage of their gauge cluster.
http://www.celica-club.ru/board/index.php?showtopic=13031 -------------------- 15PSI - 30MPG - Megasquirt Tuned
Aug 24, 2009 - 4:58 AM |
here is an interesting solution i found for those having issues with even coverage of their gauge cluster. http://www.celica-club.ru/board/index.php?showtopic=13031 they are mega bright, you'd get sun burn off them driving at night -------------------- |
Aug 24, 2009 - 1:09 PM |
http://superbrightleds.com/specs/bulb_specs.htm
these have an operating range of 9-14.5v. I wonder what the official operating rang is of the cheap leds that always blow out. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Aug 25, 2009 - 10:25 PM |
maybe the resistors suck???
Aug 25, 2009 - 11:37 PM |
hey 808 celica. your saying that the resistors on the cheap led bulbs suck. that why they have a tendancy to blow out if you dim cluster gauge lights...
and since lagos said our the dimmer can output anywhere from 11v-14v max. and those superbrightleds website specifies it that the bulbs can range from 9-14v then they will work great on the cluster gauge and will last a lifetime.... This post has been edited by BonzaiCelica: Aug 26, 2009 - 12:25 AM -------------------- Group buy to replicate Narrow E series transaxle parts
Lo-Fi Version | Time is now: November 29th, 2024 - 2:03 PM |
