Stock Camber...? |
Stock Camber...? |
Aug 23, 2009 - 3:55 PM |
Enthusiast Joined Aug 11, '09 From Buffalo, NY Currently Offline Reputation: 15 (100%) |
Are our cars equipped with a camber angle from stock? Mine's a '96 ST (as evidenced to the left) and the rear tires are cambered about 10-15 degrees...just wondering if it's the performance springs/struts being lowered or what.
Aug 23, 2009 - 8:50 PM |
Enthusiast Joined Mar 8, '08 From Orlando, Florida Currently Offline Reputation: 14 (100%) |
yes, lowering your car creates negative camber.
No, the celica did not come with a way to adjust the camber, you must purchase either "crash bolts" from the dealer which are thinner bolts which allow the strut to move in or out to correct the camber, or an aftermarket camber kit -------------------- ◊◊◊ My F/S Thread! ◊◊◊
Aug 24, 2009 - 12:24 PM |
Excellent. Thank you.
Aug 24, 2009 - 1:27 PM |
10 to 15 degrees is a bit of an exaggeration...i hope
Lo-Fi Version | Time is now: January 10th, 2025 - 7:39 AM |
