ecu |
ecu |
Aug 24, 2009 - 5:59 PM |
Enthusiast Joined Jun 24, '06 From Houston.TX Currently Offline Reputation: 0 (0%) |
i have a 97 celica gt and my ecu is gone so i was wondering would i be able to use a 99 ecu. My cluster also got messed up i have a manual celi so does it matter if i get an automatic cluster.
Aug 24, 2009 - 6:09 PM |
Yeah you can use a 99 ECU, so long as it is a manual ECU. And I believe you can use an auto cluster, but the automatic clusters have a gear select section where the manuals don't. I believe they'll work fine either way.
This post has been edited by 95CelicaST: Aug 24, 2009 - 6:11 PM -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
Aug 24, 2009 - 6:41 PM |
thanks for the help i appreciated it
Aug 24, 2009 - 7:05 PM |
Yeah you can use a 99 ECU, so long as it is a manual ECU. And I believe you can use an auto cluster, but the automatic clusters have a gear select section where the manuals don't. I believe they'll work fine either way. Mine doesn't, unless that's a '99 thing? -------------------- '97 ST \ Eibach \ KYB \ Kenwood \ Alpine \ Cusco \ OEM+ [sold 10/18]
'93 MX-5 LE |
Aug 24, 2009 - 11:05 PM |
Maybe it is just the ST202 gauges. Those are the only automatic clusters I've seen, but a quick google search didn't provide any GT or ST auto clusters, so I assume they're the same and retract that aspect of my statement.
Aug 26, 2009 - 8:51 AM |
Enthusiast Joined Apr 20, '09 Currently Offline Reputation: 4 (100%) |
Yeah you can use a 99 ECU, so long as it is a manual ECU. And I believe you can use an auto cluster, but the automatic clusters have a gear select section where the manuals don't. I believe they'll work fine either way. Mine doesn't, unless that's a '99 thing? Not in the USDM ones. Some pics in the interior/electrical section has pictures of a cluster that has a gear-select section in the third section, the one with the the fuel/temp gauges. I can't find it atm. -------------------- ~Moving on to a 2002 Corolla S~ R.I.P Tom Celica - 1994-2010 |
Aug 27, 2009 - 9:39 PM |
I ended up putting a 99 and 96 ecu and still doesnt work so that means i have to get a 97 ecu?
This post has been edited by babysupragt: Aug 27, 2009 - 10:01 PM |
Aug 28, 2009 - 12:40 PM |
I ended up putting a 99 and 96 ecu and still doesnt work so that means i have to get a 97 ecu? Are you using the correct ECU? For instance, there's a diff ECU for the 5S and the 7A, are you using the correct one? -------------------- ~Moving on to a 2002 Corolla S~ R.I.P Tom Celica - 1994-2010 |
Aug 30, 2009 - 8:22 PM |
im using a 5sfe
Aug 30, 2009 - 9:01 PM |
is there any links i can go to. To see if i can find one
Sep 2, 2009 - 5:13 PM |
finally i found a 97 ecu with the same part number but i was told that i would have to program it to my car. I was wondering if thats true can anybody help with this
Sep 2, 2009 - 6:48 PM |
same part #, should be plug and play.
Sep 3, 2009 - 12:40 PM |
thanks for the help
Lo-Fi Version | Time is now: January 10th, 2025 - 5:44 AM |
