11 Pages V  « < 7 8 9 10 11 >
> Swap: 3sge Beams into 94GT-RIP=DEAD
post Nov 9, 2009 - 2:56 PM
turnip
Joined Aug 24, '09
$12 belt from advance auto. Make was a driverite - #378K4 its a snug fit on and you have to walk it on by turning the crank and then it frees up and you tighten the tensioner. I have about 1/2 inch more on the tensioner if need be. I really struggled finding the right belt and have several hours in that project alone. The crank pulley had to be dremeled as well because of the coating where it slides on the crank. That took a while to get a nice fit but its good to go now.
QUOTE (illtuned @ Nov 9, 2009 - 3:32 PM) *
What belt did you use?
post Nov 14, 2009 - 7:59 PM
turnip
Joined Aug 24, '09
Gutting started today. Trying to decide weather to take the heat core out and if I should use the top dash plastic. The top dash pad for the celica is quite heavy. I was little suprised. Tempted to add a second small radiator under the dash in place of the heater core. Heat kills engines and in my experience you cannot keep it cool enough when racing.
This post has been edited by turnip: Nov 14, 2009 - 10:44 PM
post Nov 16, 2009 - 9:30 AM
turnip
Joined Aug 24, '09
It was so nice yesterday I decided to take it out for a quick blast before the neighbors call the cops. The road was a little damp and with the LSD and no power steering it was fighting me a little. Definitely have to be careful. At the end you hear the container of bolts and screws fly around. Borrowed my buddies headrest camera holder. Thats with the glasspack on. Since I got this camera mount I will try to get a few more videos. Just have to make sure no cops around. With the leaves falling off the trees its insanely loud.
Test Run
This post has been edited by turnip: Nov 16, 2009 - 9:32 AM
post Nov 16, 2009 - 12:56 PM
turnip
Joined Aug 24, '09
Okay only worked a half a day today and its beautiful out so I grabbed some vids with the muffler off. Probably be a couple of weeks till i get to the dyno and then all the glass comes out. Again I wish I had more room to open it up.
Video 1
Video 2
Update: Local Sherriff Showed up. Said he couldnt prove it was me but said he would keeping an eye out. laugh.gif
This post has been edited by turnip: Nov 18, 2009 - 7:36 AM
post Nov 17, 2009 - 11:42 PM
Rusty
Joined Nov 5, '07
From New Zealand
laugh.gif nice videos
post Nov 18, 2009 - 2:19 AM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
Haha I want to drive my GT4 through your neighborhood, looks like a rally stage!
Whys your exhaust so tinny? Looks like your acceleration is pretty quick for a FWD NA on that type of surface - especially when you get into the VVT-i range.
Mike W
269awhp / 273ft-lbs
post Nov 18, 2009 - 8:53 AM
turnip
Joined Aug 24, '09
QUOTE (delusionz @ Nov 18, 2009 - 3:19 AM) *
Im not sure what the diameter of the Beams exhaust was but I went from the exhaust manifold to the y collector with 2 1/8". Then from the y collector to muffler is 2.25. Its short in length on purpose. One is weight and the other is that they seem to always get torn off racing when you have to drive into the infield to avoid a pile up or if the track is really rough. It definitely was more responsive without the muffler.
As for acceleration, all thats left in the car is the glass. Definitely removed over 150lbs in weight and taken 8-10lbs off the crank via lightweight crank pulley and flywheel. In addition power steering is usually a hog of horsepower and thats no longer on the car. Just the altenator. Should get it on the dyno by month end.
This post has been edited by turnip: Nov 18, 2009 - 8:55 AM
post Nov 20, 2009 - 8:42 PM
delusionz
Joined Feb 11, '08
Yeah I meant tinny (not tiny) as in sounds like a stone in a tin can. But since you mention you had no muffler on it, that explains why.
Mike W
269awhp / 273ft-lbs
post Nov 24, 2009 - 8:55 PM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
how much weight did you save by taking out the power steering???
post Nov 24, 2009 - 9:30 PM
turnip
Joined Aug 24, '09
AC was 15lbs
PS was 9lbs
Hoping to gain some extra horsepower by reducing parasitic loss caused by both. With that said, I suspect that the toyota design will be more efficient than the Dodges and GMs and the gain could be less but will see in a few weeks after the dyno.
QUOTE (BonzaiCelica @ Nov 24, 2009 - 8:55 PM) *
post Jan 19, 2010 - 2:27 AM
BonzaiCelica
Joined Apr 24, '08
almost been 2 months since your last post. any updates?
post Jan 19, 2010 - 7:11 AM
turnip
Joined Aug 24, '09
Thanks for the reminder. Had some crazy crazy personal stuff to deal with plus been sick for about a month and with the holidays and work I just got destroyed. With that said, glass is all out and cage is in. I will post up some new pics today. I finally got a new camera as well.
post Jan 19, 2010 - 11:30 AM
turnip
Joined Aug 24, '09
So finally got the new plasma out over the weekend and jumped in with my buddy and hammered it out. Not far from completion on the inside. Need to fab up some bumpers.
This post has been edited by turnip: Jan 19, 2010 - 10:24 PM
post Jan 19, 2010 - 5:22 PM
that is nuts, wow. amazed by the work, cant wait to see it finished
post Jan 19, 2010 - 5:34 PM
BonzaiCelica
Joined Apr 24, '08
keep up the good work!
post Apr 3, 2010 - 7:48 AM
turnip
Joined Aug 24, '09
Tracked it last night. Got spun into the wall but damn its flies. Will post up some pics later. Again thanks for all the help everyone. Need wider tires and suspension tweaking now and it will really fast on dirt with the rest of the cars im running with.
post Apr 3, 2010 - 9:21 PM
turnip
Joined Aug 24, '09
So last night was first time out on the dirt. Need to lower the car and get wider tires. I should be able to squeeze 225s or 235s on the front. Also gonna need a new rim and strut from hitting the wall. Anyone have spring they can recommend?
post Apr 4, 2010 - 12:47 PM
how do you like it, i love mine
post Apr 4, 2010 - 12:56 PM
Who would've thought that a BEAMS would be powering that thing...nice though.
And I would personally recommend Eibach Sportline springs, nice drop and increase in stiffness, but it's not too low. I assume you can't go very low on a dirt track.
post Apr 5, 2010 - 10:39 AM
turnip
Joined Aug 24, '09
Love it. Just cant wait to have tons of traction compared to what I had. Definitely looking into the eibach springs now. Trying to decide on what tire to go with 225/60 or 245/55-15? I cannot find a 245/55-15 which would be the ideal tire height. So I can go with the 225s or try to find a 16" with the right offset thats 16x7 to accomodate a 245 since there is more tire options for that width and the 16 rim.
Update: Decided to go with the 225s now since they can be on for this weekend. Will have to find a rim that can supports the 245s
This post has been edited by turnip: Apr 5, 2010 - 12:53 PM
7 User(s) are reading this topic (7 Guests and 0 Anonymous Users)
Lo-Fi Version Time is now: January 11th, 2025 - 11:21 PM
