11 Pages V  « < 3 4 5 6 7 > »
> Swap: 3sge Beams into 94GT-RIP=DEAD
post Sep 22, 2009 - 10:37 AM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
QUOTE (njccmd2002 @ Sep 21, 2009 - 11:28 PM) *
so any 7 redline 3sge will work?
see I told you soo. 2bcelica just did the swap and i understood him just fine.
thanks for backing up that info pasqual.
post Sep 22, 2009 - 1:02 PM
well i just asked in mr2/beams
1. Beams tacho is just swapped and fine.
2. Any other needs mods, signal change, or adapters.
One of the guys over there tried a 7rpm redline new 3sge and it did not work....
post Sep 22, 2009 - 1:06 PM
2bcelica
Joined Mar 22, '07
From Murphy, TX
you do need the beams 9k rpm tach swapped into the st204 cluster housing - other wise your rpm will not work. I have confirmed this.
post Sep 22, 2009 - 7:16 PM
BonzaiCelica
Joined Apr 24, '08
ah really dayum that sucks. Well thats not my concern, just the fact that its white (can you get the gauge plate to be black like the 3rd gen 3sge) if you put a white cluster light behind it the color doesnt come out very white. or atleast thats what you have tested on the gauges, right 2bcelica???
post Sep 22, 2009 - 9:50 PM
2bcelica
Joined Mar 22, '07
From Murphy, TX
yeah - the led bulb i got from superbrightleds.com didn't come out well on the beams white face. I have seen on ebay that there are black 9k gauges for the beams, so if ur lucky you can get one thats black. I like the white, but doesn't look good at night, I might have to get a brighter bulb.
post Sep 22, 2009 - 9:57 PM
turnip
Joined Aug 24, '09
Intake arrived today. Its pretty chinsy but it should work for what I need. AFM did fit in. Have yet to start it back up. Still working on exhaust. Jegs y collector should be here tomorrow.
post Sep 22, 2009 - 10:04 PM
2bcelica
Joined Mar 22, '07
From Murphy, TX
QUOTE (turnip @ Sep 23, 2009 - 2:57 AM) *
Hey, take some pictures of progress when you get a chance. I'm still working on my idling issue. I played with the timing, but it didn't resolve. I left it on jack stand for now since I got caught up with work. I will be working on it again tomorrow.
post Sep 23, 2009 - 12:53 AM
QUOTE (njccmd2002 @ Sep 22, 2009 - 2:02 PM) *
just to clear things up, our rpm cluster reads the signal from the distributor/igniter. The beams rpm dial is different because is reads a different type of signal because it doesn't have a distributor/igniter wink.gif
so the answer is what 2bcelica has been saying (and what outsider said 4 years ago), the rpm gauge in your cluster will not work with the beams motor.
It's not able to interpet the signal the beams is giving it. To have a working rpm gauge just use the beams one, or use a signal adapter like the one pasqual posted a link for.
post Sep 23, 2009 - 1:46 AM
BonzaiCelica
Joined Apr 24, '08
alright thanks. Dont really understand how to do that, but hopefully these toyota electrical classes that im taking will help me understand on how to convert the signal.
post Sep 23, 2009 - 2:12 AM
Rusty
Joined Nov 5, '07
From New Zealand
thanks batman that was the point I was trying to make, since the 3gen 3sge still runs on the same type of signal as your ST204, but ours has a larger rpm range
I have heard of people doing a BEAMS cluster sawp onto a 3gen 3sge and they had to rewire it, I didn't know about that adapter, would make things alot easier.
post Sep 23, 2009 - 4:17 AM
QUOTE (turnip @ Sep 22, 2009 - 9:57 PM) *
which intake did you buy?
post Sep 23, 2009 - 4:23 AM
been looking at the wiring, so..
why do we need our original 5sfe wiring. im assuming just that part from the fusebox to the lamps. cuz the rest is not being used. apart to use it to leghten wires?
im confused. You lengthen some wires and repinn some, thats fine, but whats the real use of the rest of the harness.
post Sep 23, 2009 - 7:17 AM
QUOTE (njccmd2002 @ Sep 23, 2009 - 5:23 AM) *
you use the entire beams harness.
this is the wiring IIRC
where the fuse box is in the engine bay the engine harness unplugs from it.
You plug the beams engine harness into your fuse box in your engine bay, that plug is EA1.
Each pin on EA1 is numbered, you need to bridge together pins 4 and 17 (the US harness doesn't have pin 17 and beams pin 17 needs + when 4 has it.)
on the other end of the beams engine harness there are 3 interior plugs (3 vertical plugs right next to the ECU).
The beams ECU has 4 plugs and the circuit opening relay (COR).
The 3 interior plugs are white (19 pins), light grey (13 pins) and dark grey (17 pins)
the black wire from the white plug (pin #18) must be removed and re-pinned to the dark grey plug into pin # 17.
that is the wiring. Do those things and the car starts, drives, ect..
fyi if you want cruise control or airbag light to work, there's a bit more.
As for extending the harness, you would need to extend some wires to fit into the LHD configuration or you make a new hole in the firewall and put the harness through it there.
post Sep 23, 2009 - 7:23 AM
turnip
Joined Aug 24, '09
QUOTE (njccmd2002 @ Sep 23, 2009 - 5:17 AM) *
I bought the chinsey one off ebay for 37 and free shipping. The link is page back.
I really havent made much progress since getting the engine in and running. I have boot on a tie rod leaking so I decided to fix that while its apart. Since I took the P/S off its critical to keep fluid in the rack. Plus I hate drippy cars. Its just been collecting dust on Jack stands the past week. I have had like no free time the past week. Trying to find a crank pulley but unorthodox stopped making them a year and half ago for the 5sfe/3sgte which is suppose to fit. They said they would make a custom one for 500. So now looking at a C-One or Beatrush. $300 clams plus shipping is a lot of dough for a crank pulley.
This post has been edited by turnip: Sep 23, 2009 - 8:06 AM
post Sep 23, 2009 - 7:58 AM
QUOTE (Batman722 @ Sep 23, 2009 - 7:17 AM) *
airbag light kind of important, will check that out. i have cruise, ill try to figure it out, if i cant ill pm you
post Sep 23, 2009 - 8:15 AM
turnip
Joined Aug 24, '09
Batman we appreciate all the help.
post Sep 23, 2009 - 10:09 AM
BonzaiCelica
Joined Apr 24, '08
get the lightweight c-one pulley from nengun.
post Sep 23, 2009 - 10:14 AM
99GT
Joined Dec 14, '06
From MN, USA
post Sep 23, 2009 - 12:00 PM
pasqual
Joined Nov 4, '06
From POLAND
turnip can You put point by point problems you need to solve ??
is not easy track conversation , is not clear what is done and what you need to fix ...
1. idlle problem -- status ?
2. rpm gauge -- status ??
etc.
BEAMS swaped .......
post Sep 23, 2009 - 12:35 PM
turnip
Joined Aug 24, '09
QUOTE (pasqual @ Sep 23, 2009 - 12:00 PM) *
etc.
At this point the only issue I have is lack of $$$ and time. Appreciate the offer to help. Im sure something will pop up once I get it ready to start beating on it. Right now I just need to get it back together.
7 User(s) are reading this topic (7 Guests and 0 Anonymous Users)
Lo-Fi Version Time is now: January 11th, 2025 - 11:18 PM
