Coilover, Coilover |
Aug 26, 2009 - 10:46 AM |
Enthusiast Joined Aug 6, '09 From Quebec Currently Offline Reputation: 0 (0%) |
I have a set of adjustable coilover but there is 2 type of spring (on then top end is flast and the others is not) And 2 set of bolt (longer-shorter)
Wich Spring Goes with Wich Bolt? and Wich one goes in the front and in the back!?? Thanks! (Ground Control Coilover) |
Aug 26, 2009 - 11:04 AM |
Don't you have the box they came in? It should tell you spring numbers for front and rear.
And IIRC, the threaded sleeves are all the same length. Is that what you mean by bolt? -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
Lo-Fi Version | Time is now: November 26th, 2024 - 6:33 AM |
