boost leak?, not getting any boost :( |
Aug 31, 2009 - 4:42 AM |
Enthusiast Joined Apr 26, '09 From Australia Currently Offline Reputation: 1 (100%) |
so i have finished (maybe) my 5sfte conversion... when i fire it up, it runs and the boost gauge shows a manifold vacuum at idle.... but then when i rev it, it hits 0psi and goes no further...
It is also making a whistling sound (which would indicate a leak?) any ideas? -------------------- ST184R - Project 5S-GTE - Audio: Eclipse CD4000, SW7200, XA1000, SC8265, EA2000 Engine: Greddy eManage, 360cc Injectors, CT26, FMIC, Walbro 255, K&N Pod, Blitz MSTT, HKS SSQV, 3SGE Head Swap, Suspension/Brakes: craftz coilovers, Gen 3 Camry Hub Swap Wheels: ROH Boost-R 17x7 - Times: N/A: 16.73, FI: Coming Soon
NCP91R - Almost JDM - Audio: Eclipse SW7200, XA1000, Jaycar LLC Engine: Resinator Removed Exterior: Domo toy, Foglights Wheels: 15in Steelies Times: N/A: Coming Soon |
Aug 31, 2009 - 12:07 PM |
Enthusiast Joined Dec 4, '07 From Northeast Pennsylvania Currently Offline Reputation: 3 (100%) |
so i have finished (maybe) my 5sfte conversion... when i fire it up, it runs and the boost gauge shows a manifold vacuum at idle.... but then when i rev it, it hits 0psi and goes no further... It is also making a whistling sound (which would indicate a leak?) any ideas? check your piping. -------------------- QUOTE ‹Superaison› i'm a computer inclined guy.. ‹Superaison› or girl. idk what gender I am anymore. ‹SeverX13› *facepalm* QUOTE suprakid: o sh!t suprakid: i wanna get an obama chia pet SeverX13: hahahahaha |
Aug 31, 2009 - 12:10 PM |
Enthusiast Joined Aug 7, '05 From Columbus OH Currently Offline Reputation: 3 (100%) |
Check for leaks...probably your issue. Also, if you're just revving your car from idle you probably wont see any boost on the gauge.
Aug 31, 2009 - 1:42 PM |
so i have finished (maybe) my 5sfte conversion... when i fire it up, it runs and the boost gauge shows a manifold vacuum at idle.... but then when i rev it, it hits 0psi and goes no further... It is also making a whistling sound (which would indicate a leak?) any ideas? You do realize you need to drive the car under load to make boost, right? -------------------- 15PSI - 30MPG - Megasquirt Tuned
Aug 31, 2009 - 2:21 PM |
Enthusiast Joined Mar 29, '07 From Philly Currently Offline Reputation: 11 (100%) |
yea reving it it will not make boost...throw it in 3rd on the highway and romp on it...see what its reading...then report back...i know i have a boost leak somewhere...i just have to rip apart my pipeing again and tighten everything up, and go over my vac lines once more. mine is making a loud hissing noise under boost and it doesnt feel as powerfull as it use to be in 4th and 5th
-------------------- I"M NOT A TOYOTA FAN, IM A FANATIC 1984 accord hatch 5 speed (T-Belt)-Junkyard 1991 VDUB jetta wolfsburg Ed. 5 speed (clutch)-junkyard 1988 Dodge Aries K (sold) 1969 Chevy El camino - Traded for celica 1991 Dodge Daytona-Traded for Celica 1988 Chevy Camaro-Work in Progress 1989 Ford Mustang LX 5.0 - For Sale 1995 Toyota Celica-Work in Progress |
Aug 31, 2009 - 5:25 PM |
probably should clarify... it was not making boost under load either... i did take it for a brief drive, took it to 4-4500 rpm, and still nothing.
i have gone through and checked all my piping and it all appears to be secure... could perhaps the wastegate flap be stuck open? -------------------- ST184R - Project 5S-GTE - Audio: Eclipse CD4000, SW7200, XA1000, SC8265, EA2000 Engine: Greddy eManage, 360cc Injectors, CT26, FMIC, Walbro 255, K&N Pod, Blitz MSTT, HKS SSQV, 3SGE Head Swap, Suspension/Brakes: craftz coilovers, Gen 3 Camry Hub Swap Wheels: ROH Boost-R 17x7 - Times: N/A: 16.73, FI: Coming Soon
Aug 31, 2009 - 7:47 PM |
Could definitely be your wastegate. If you aren't making any boost at all under load then you must have a pretty big leak somewhere or your turbo is lame I would suggest making a leak tester or buying one online...I myself need to invest in one. Good luck with your search.
Aug 31, 2009 - 10:20 PM |
I will fool arround with the wastegate and take it for a spin, if that does not solve the issue i will make a boost leak detector.
Lo-Fi Version | Time is now: November 28th, 2024 - 6:59 AM |
