> Painting Wheels
post Sep 1, 2009 - 1:35 AM
Davesceli
Joined Apr 24, '04
From S. Cali
I wanna repaint my wheels but am unsure as to whether my wheels are powder coated or painted. Is there any way to tell? If it is powder coat how do i remove it...can i just scuff it and paint over it?
Also what paint should i use, I was contemplating using the ceramic engine coating over the dupli-color wheel paint? Any suggestions?
This post has been edited by Davesceli: Sep 1, 2009 - 1:42 AM
post Sep 1, 2009 - 7:31 AM
It doesn't really matter if you're wheels are powder coated or painted to start with.
You are going to want to sand the surface down pretty good starting with a low grit and working your way up to like 800.
wash the wheels and let dry, wipe with a tack cloth
Lay down some primer in a couple layers
wet sand with high grit, then reprime any bad areas to make sure its all even
rinse/dry/tack cloth
Lay down paint, light even layers.
wet sand/dry/tack
Clear Coat
wetsand/dry/polish
post Sep 1, 2009 - 9:34 AM
Nartanian
Joined Mar 26, '09
From Minnesota
This should help I hope.
http://www.youtube.com/watch?v=q5eK5OnHfqA
"God created turbo lag to give V8's a chance"
post Sep 1, 2009 - 3:29 PM
I'm gonna be taking this on in a while and that video raised some questions for me. I always thought that the inside of the wheel should be painted as well, yet that guy in the video didn't, it seemed...so would you say it's necessary? Seems like it would take away from the overall look if the inside was still silver. kindasad.gif
post Sep 1, 2009 - 4:11 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
Of course you paint the inside of the rim. The guy in the video did as well, but he didn't show it, because you should understand what you have to do. Much like how he didn't show him clearcoat the wheel.
**** Photobucket
post Sep 10, 2009 - 1:57 AM
xlee
Joined Apr 22, '09
From MN
QUOTE (Davesceli @ Sep 1, 2009 - 1:35 AM) *
I would use paint remover to take the paint off, you'll save so much more time over sanding. i tried sanding and it was a tiresome killer job! After that i sand blasted it off with glass and it looked pretty much new. i'm still waiting on my powder coating system to arrive. You can pick those up for pretty cheap now.
post Sep 16, 2009 - 12:52 AM
RocketScott
Joined Nov 21, '05
From Tacoma, WA
The stock wheel paint is hard to get off. Paint remover takes a while but is less effort than sanding. You really don't need to get down to bare metal though. As long as the paint that is on there still has good adhesion then you shouldn't need to get it all off. Sanding should be done to smooth everything out. Go through the prime/sand cycle a few times till everything is smooth.
I built a blast cabinet to strip everything off but I plan on getting my rims powdercoated. That's really the quickest, easiest way to do it. Most powdercoating shops also do sandblasting or contract it out as part of the deal.
Oh, and that video was terrible. The finish looked like crap on video which means it looks even worse in real life. As was mentioned before he didn't paint the inside of the wheel. He also didn't take the valve stem out.
This post has been edited by RocketScott: Sep 16, 2009 - 10:35 AM
post Sep 16, 2009 - 7:14 AM
I'm doing mine right now. But I have 2-piece BBS wheels.
1st i removed the face of the wheels (spokes/center) from the barrel of the wheel, by unscrewing all my bolts (~20 some of them)
once removed i sandblasted the centers front and back, then did some 400 grit sanding work pretty quick.
then primer, paint, wet sand, clear, wet sand, polish, wax
Lo-Fi Version Time is now: November 27th, 2024 - 9:49 AM
