7afe ebay Header MOD?, O2 sensor in the wrong spot |
Sep 1, 2009 - 8:47 PM |
Enthusiast Joined Apr 13, '09 From pittsburgh Currently Offline Reputation: 3 (100%) |
Now i bought the current Ebay header for the 94-99 celica which mine is a 96. Now my engine does have a cat but it is not off the exhaust manifold it is past the mid pipe, no worries there. Other than that it will take place completely of the one i have and everything looks like it will bolt on directly. The only difference is that the O2 sensor that they have on the ebay header has the bolt on style O2 sensor and mine is the screw in one. Also my current position is a lot lower on the exhaust manifold and reads all 4 cylinders where as the ebay header is on the left and reads only one cylinder. Someone has had to run into this. I know i could plug the bolt on hole by making a plate but what about my O2 sensor it would have to go much lower on the header to read all 4 cylinders? If I just keep it unplugged will it make my car run like crap?
Current Ebay Header Thanks in advance for the help |
Sep 1, 2009 - 9:48 PM |
Enthusiast Joined Apr 20, '09 Currently Offline Reputation: 4 (100%) |
That header says it is for the 3S-GE, not the 7A-FE.
-------------------- ~Moving on to a 2002 Corolla S~ R.I.P Tom Celica - 1994-2010 |
Sep 1, 2009 - 10:15 PM |
3SGE is a 2.0, and that header is meant for a 7AFE.
This is a GT header. You can have a shop block off that o2 area and have them weld in a bung for yours. And the secondary section needs to be lengthened to meet up with your exhaust. -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
Sep 1, 2009 - 10:31 PM |
QUOTE (eBay Auction) Applcaition:
I know the 3S-GE is 2.0L, so the description must be wrong. This post has been edited by solidxsnake: Sep 1, 2009 - 10:32 PM -------------------- ~Moving on to a 2002 Corolla S~ R.I.P Tom Celica - 1994-2010 |
Sep 2, 2009 - 7:31 AM |
Ok maybe I should have read the ebay posting before I listed it, no matter here is another one, and maybe this is better
http://cgi.ebay.com/ebaymotors/CELICA-ST-1...sQ5fAccessories Well its the same freekin header or at least the same design, it looks exactly what I have minus the better pipe lining than the exhaust manifold, it will bolt exactly to my existing exhaust without an extending piece, and only has one O2 sensor which needs to be moved, Being that it is stainless can i weld a regular bung to it and where do I weld it on the 2 pieces where it will read the best? The pipe is still kind of split right before the flex pipe and after that were going to the bottom of the engine. |
Sep 2, 2009 - 7:34 AM |
yea, i'd say wrong description but just incase don't buy that one.
yes, you could relocate the sensor to read all the banks but it doesnt really matter. mine ran fine for years reading only two cylinders since they're the leanest two cylinders. you'd have to put the sensor much farther away than a non heated sensor should be which will cause more problems then just reading 2 cylinders. it'll take forever to heat up and respond too slowly that far away. the engine will feel a little 'off' and probably consume more fuel. i had my wideband down in the single pipe near the axle and it had a good .5 to .8 second response time, theres no where else to put a sensor since you'll be at the wrong angle to mount one or it'll be hanging down to be hit by road hazards. -------------------- |
Lo-Fi Version | Time is now: November 23rd, 2024 - 8:16 AM |
