> Speakers
post Oct 25, 2003 - 7:53 PM
amory_Tarr
Joined Sep 9, '03
From wisconsin
which speakers should i replace the stock speakers with? I am fairly sure i'm getting a Boston Acoustic 6 comp set handed down to me and then i'm looking at a 4 channel fosgate amp but what about the 2 rears? They're 6 1/2" but looks that you could fit up to 8" by the enclosing size? Recomendations for the back two? Playing hard rock, NOT rap and am using an alpine 9807 head.
Thanks to all,
Amory
post Oct 25, 2003 - 8:03 PM
Guest_Matthew_*
umm
try to get them all the same brand and model
like lets say for example there are alpine type r components for the front
well then get alpine type r 6 1/2 two or three ways in the back
its called voice matched
so it all sounds the same
post Oct 25, 2003 - 8:44 PM
amory_Tarr
Joined Sep 9, '03
From wisconsin
post Oct 26, 2003 - 12:19 AM
amory_Tarr
Joined Sep 9, '03
From wisconsin
Also, are the BA PS 6 Comps a good set of speakers? i would be getting them as an x-mas present so i'm not paying for the comps, it'd just be for the 2-way.
post Oct 26, 2003 - 2:51 PM
Guest_Matthew_*
honestly i havent heard their speakers before besides on a computer. i have heard of the company though.
check out some reviews for them
type in BA PS 6 reviews in google or yahoo.
post Oct 27, 2003 - 10:05 AM
AudioFreak
Joined Dec 19, '02
From West of Atlanta
QUOTE (amory_Tarr @ Oct 26, 2003 - 1:19 AM)
Boston Acoustics makes some incredible stuff. I'd compare them too MB Quart. Considered audiophile quality. The rockford amp would work but with speakers of that quality I'd get a better amp. The Xtant A4004T is rated at 50x4 and sells for a little over $225.
post Oct 27, 2003 - 5:21 PM
amory_Tarr
Joined Sep 9, '03
From wisconsin
Ok, well $ is short and since i wouldnt be paying for the comps; just the two-way, i think i'll stick with the B.A's. Also, are you implying that Fosgates are bad amps or just that there are better? because its not like they are bad amps when compared to say sony and sorts like that. Plus with the comps, wouldnt you want more than 50 RMS watts pushing them? they're rated for 20-200; so wouldnt having 65-80 RMS watts and not pushing the amp as hard be a little better or is that off base?
Thanks,
Amory
post Oct 27, 2003 - 5:42 PM
Guest_Matthew_*
by saying that the xtant is a better amp than RF is that the sound quality is better
better configuration, better transformers, resistors, etc. all the electronics, signal processing, and everything else is made at a higher quality.
companies like sony are all about the mass sales.
look at it this way
which is better civic ex or McLaren F1
obviously the McLaren because its mostly hand made and better materials go into the construction than the civic
so the xtant is mclaren and sony is honda
and no xtant isnt the best it was just an example comparing it to the McLaren
post Oct 27, 2003 - 5:43 PM
Guest_Matthew_*
also for wattage its good to go to the mid high range for them
anything above 20 watts will make them sound decent but generally speaking the more watts the better.
its like gas for your car
racing fuel will make it perform WAY better than 87 octane pump gas.
post Oct 27, 2003 - 6:30 PM
AudioFreak
Joined Dec 19, '02
Also the higher quality amps generally give you more wattage than they are rated for.
post Oct 29, 2003 - 5:15 AM
SoundSlut_dotcom
Joined Feb 16, '03
u can fit 6x9's in the back if u want
post Oct 29, 2003 - 7:00 PM
amory_Tarr
Joined Sep 9, '03
From wisconsin
THe only thing about the Xtant one you recommended is that its 50W @ 2ohms and 25W @ 4ohms VS the 140W @ 2ohms and 70W @ 4ohms of the comprably priced RF 551X. How much extra wattage would the Xtant be putting out? Otherwise, we've had a few RF Punch amps before and been satisfied with how they sounded, so whatever i can get a better deal on would be my best bet.
post Oct 30, 2003 - 4:23 PM
initialdrift55
Joined Sep 23, '03
From Miami,FL
i just replaced my stocks with Sony 3 way speakers...fronts and back 6x8 i believe........sounds awesome ill take pictures
post Oct 30, 2003 - 9:06 PM
Drocay
Joined Oct 3, '02
From Va Team 6gc
Most deffinitly go with the BA they sound great my uncle just put some in his car, its pure quality.
Team 6gc 2005
post Oct 30, 2003 - 9:21 PM
celicagt94
Joined Feb 3, '03
From Maryland
how did u fit 6 x 9's in the back
post Oct 31, 2003 - 12:45 AM
initialdrift55
Joined Sep 23, '03
From Miami,FL
my bad to correct my last post i didnt put 6x8's i have 6 1/2....still sounds awesome
post Oct 31, 2003 - 5:12 AM
SoundSlut_dotcom
Joined Feb 16, '03
6 1/2 in front and 6x9's in the back.. dont remember exaclty how but it worked.. ;/
post Nov 3, 2003 - 3:11 AM
van95st
Joined Sep 6, '03
From Fairbanks AK
if your running components up front that's more than enough high's for the car i would suggest running drivers in the rear. they are designed more for mid to low range and will suppliment the components. as far as size that all depends on how crazy you wanna get with the install. 6.5" fit without any fabrication, just a little nipping and tucking.
Lo-Fi Version Time is now: November 28th, 2024 - 3:09 PM
