Enthusiast Joined Sep 6, '09 From Auckland, NZ Currently Offline Reputation: 0 (0%) ![]() |
Hi Guys, small problem. I got a 1997 Celica ST202 Engine 3S-FE the parts dealer I deal with have told me they don't have a listing for a head gasket kit for this engine. does the 3s-ge or gte or ???
![]() ![]() Thank you! |
http://www.toyodiy.com/parts/p_J_1997_TOYO...BLMGK_1104.html
11115-74110 that is the part #. they were probably only looking in the EU version of the EPC, which does not contain parts listings for the 3sfe. -------------------- Former Team 5SFTE pro member ;)
http://www.toyodiy.com/parts/p_J_1997_TOYO...BLMGK_1104.html 11115-74110 that is the part #. they were probably only looking in the EU version of the EPC, which does not contain parts listings for the 3sfe. Hey presure2 thank you for this! ![]() ![]() |
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Nov 5, '07 From New Zealand Currently Offline Reputation: 3 (100%) ![]() |
I personally wouldn't deal with BNT.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 11, '08 From Auckland, New Zealand Currently Offline Reputation: 0 (0%) ![]() |
Try another BNT, You can ask them to search Toyota Corona 2.0 - 3S-FE, may even be cheaper if they cant find ST202 3S-FE.
Their parts DB is fuct, I wanted a panel filter for my GT4 and the part listed for ST205 is too small for the air box, They found the product code for the correct fitting panel filter under Toyota Corona 3S-GTE which is strange -- Even then u have to clip the corners to the lid fits over it. -------------------- Mike W
Enthusiast Joined Mar 17, '09 From New Zealand Currently Offline Reputation: 0 (0%) ![]() |
The Toyota Carina ED used the ST-202 3SFE engine as well. That engine is used in several cars. In fact Pick-A-Part in Lower Hutt has some 3SFEs there, but if you're in Auckland I guess that ain't much use....
In fact I would also recommend calling Toyotaz Galore, I've purchased a few parts through them and they have shown themselves to be reliable so far. They're based in either Manurewa or Manukau I believe. This post has been edited by Dickson: Sep 7, 2009 - 12:21 PM |
whats wrong with going to toyota, besides the price?
Lo-Fi Version | Time is now: February 18th, 2025 - 2:30 AM |
