> air conditioning...1994 celica 1.8
post Sep 6, 2009 - 9:31 PM
optik_3000
Joined Mar 9, '09
From Los Angeles, California
i am having trouble with my air conditioning system...it wont work...it was working one week then another week nothing...no relays or fuses are burned...engaged the compressor with direct power and it does work...it just doesnt work wen i try to turn it on with the ac button on the inside...if anyone can help me i would appreciate it...thanks...
post Sep 9, 2009 - 11:14 AM
Espo
Joined Aug 11, '09
From Buffalo, NY
Make sure your harness for the a/c button on the back of your climate control box is in. In fact, make sure all the harnesses are in. Can you hear the compressor click or not when you hit the a/c button? Stupid question but I'm not quite sure I understand what you're saying.
post Sep 9, 2009 - 11:44 AM
Cavegod
Joined Jul 11, '09
From UK
unclip the pressure switch and short the two inside pins together and then try the A/C. if that works leave it running for a few minutes then clip the wires back onto the sensor and try again, if still nothing you need it re gassing.
post Sep 9, 2009 - 1:30 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
my best bet would be you are low on refrigerant. Go get some R134a, yo
Lo-Fi Version Time is now: November 24th, 2024 - 6:00 AM
