2 Pages V  < 1 2
> Beams Red top Vs *MZ-FE, Nope, no 3sgte please.
post Sep 10, 2009 - 3:16 AM
Rusty
Joined Nov 5, '07
From New Zealand
3sge, I have decided against this
I guess your missing the T
go 3gen 3S-GE or BEAMS. if you need more convincing you could go see 2bcelica (dont know how close he is to you though?)
post Sep 10, 2009 - 7:27 AM
Cavegod
Joined Jul 11, '09
From UK
we have a V6 GT4 in the uk, uses a Rav4 transfer box as the GT4 box won't bolt to the fe block.
post Sep 10, 2009 - 8:23 AM
fibrewizard
Joined Sep 8, '09
From australia, east coast
QUOTE (Cavegod @ Sep 10, 2009 - 8:27 AM) *
it does with minor mods..... but nice use of the rav 4 transfer case........... how is it with the rav4 diff centre......
st184 3vz-fe convesrion complete
st185 AWD 3vzfe turbo conversion in progress
and stock st204 daily....
post Sep 10, 2009 - 3:49 PM
made a decision... few months i will have more details...
post Sep 13, 2009 - 7:51 AM
K-ESD
Joined May 5, '05
From New-Brunswick Canada
Well obviously I'm going to say go for a V6, trust me you won't regret it.
http://www.youtube.com/watch?v=K9VMmMCc0UM
here's to clear up and confirm some myths
no, it does not make your car heavy
mine weighs in at 1220kg with all my extras and 1/4 tank of gas
yes it can be done cheaper than the Beams
yes there is virtually unlimited amount of easy to find parts for cheap
yes, it's very good on gas when babied, it's not bad when floored, in fact it's far better than 5SFE in town.
and NO it does not make it hard to work on, at all
it's makes it easier to work on that a 5S, some people say that and they never worked on one or even seen one rolleyes.gif
there is plenty of room all around of the engine. I don't need to squeeze into tight spaces. I can reach any spot with a wrench from top or bottom, as long as my arm is long enough.
edit: and no you don't need a lowered custom cross member, i used the stock cross member + GT4 mounts with E153, you can even use the stock GT tranny but it's not as strong.
This post has been edited by K-ESD: Sep 13, 2009 - 8:01 AM
----------------------6GC's FIRST V6----------------------
JDM 96 MR2-T Faster - 94 Celica GT 3MZFE Funner - 99 Rav 4 AWD Handy
post Sep 13, 2009 - 1:22 PM
Edophus
Joined Apr 20, '06
being a beams man myself i'll stick up for the beams to keep things from being one sided tongue.gif, It makes a lot of sense to choose the v6 for sure, and i think it'll make for a better road car, and economics and parts availability is a major factor in any choice, but if your looking for outright speed without opening the engine up i think the beams still has the edge, simply because the power band of the v6 is not matched to the gearboxes available to you.
Also i know of two 1mz-fe's here in the uk that are making 10bhp less than an unopened beams with the same mods and same aftermarket ecu, tuned by the same guy on the same dyno, and thats at only 7000rpm so not taking advantage of the engines rev potential which means with an ecu the beams keeps making power up to 8000rpm ( and beyond if you dont like your bottom end ), where as the v6 will probably be shifting 1500-2000rpm earlier. There are tuning parts available for the beams but its not a cheap engine to tune for sure, and your limited to only a few sources for parts, plus the knowlodge is heald by only a few people but it is all out there.
There is also a lot of subtle differences, such as the oiling of the engine, its only really relevant in a track situation though but the beams is a race engine ( it was built to race in N1 endurance, and formula 3000 where the rules mean you cant modify the engine ) so has sufficient oiling and baffling from the off whilst the v6's can overheat quite easily in the same scenario's because they carry the same amount of oil but the v6 has a lot more parts to cool. A lot of work has gone into the beams in this area which is obvious when you note things like the external oil drain from the side of the head to the sump etc. Toyota still use the beams for racing, its still in formula 3000, and is currently powering the s2000 corolla in rally's.
Also the weight of the 1mz is pertty much identical to the beams, with the beams probably a kilo or 2 lighter, people say the v6 is lighter, but thats because there comparing it to the 3s-gte, which has a turbo hanging off the side, and an intercooler sitting on top, the turbo alone weighs about 14kg.
heres a vid, excuse the poor quality you'll really need to peer at it, of a 2nd, 3rd and 4th gear pull in my old beams, its up a slight uphill but not that much to make a huge difference, i also had a bust thermostat, but i let it heat up before the run so i dont think it would have been pulling ignition timing. I tried to edit the vid in sony vegas to make it brighter but it wouldnt work frown.gif
http://www.youtube.com/watch?v=FXWuBR_5HGA
I usually say to people if its a track car then beams, if its a road car v6. I will say for most folk the v6 is going to be the more entertaining option because of the torque and noise.
This post has been edited by Edophus: Sep 13, 2009 - 1:55 PM
post Sep 13, 2009 - 7:57 PM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
very nice reply edophus. you always know what to say and have very useful information that members can go back on.
hold up a sec k-esd. your telling me that your car weighs 1220kg. i think the celica with redtop weights in a 1185 kg = 2600 pounds. is this true edophus
post Sep 13, 2009 - 9:30 PM
K-ESD
Joined May 5, '05
I agree with you for the most part Edophus, very well said.
However, we have the gearbox that matches the engine. The E-153 is perfect for a V6, wide enough to make good use of the torque curve. It also comes with the Solara V6 with a slightly wider final gear.
I still think the V6 has it's place in the racing world, maybe not endurance but enthusiast track racing for sure. A lot of Mr2 guys are ditching their NA and turbo 4 bangers for V6s for racing purposes.
also keep in mind there are 5 V6 options, the 1MZ is only of one them and far from the best. I would only get a 1MZ at a dirt cheap price, then slap on a TRD SC.
a non-vvti 1MZ would be in par with the 3SGE power wise but look at the 1MZ vvti (220), 5VZ (201) and 3MZ (230), all of them over 200HP.
now lets throw the 2GRFE into the mix
276WHP bone stock reliable and still gets 30MPG, anyone want that?
This thing would rival even a slightly built 3SGTE
The V6s has many advantages in racing just like the 3SGE has it's advantages but, like you said, what's best is all about what the person wants to do with the car.
now to steer away from my V6 biasing....
I'm bored of the 3MZFE and moving into a higher power goal (300HP+). I'm picking up a 96 MR2 turbo next weekend. This will be my next project car, I guess hanging around in the MR2 boards influenced me enough to get one. The 2GRFE would have been too much for a FWD platform, I needed a change and want to experience a turbo car. I am considering stuffing a 2GRFTE (FTE !!) in the MR2 at some point in the future if it's feasible and financially possible for me.
post Sep 13, 2009 - 9:37 PM
Where does the 2GRFE come from?
post Sep 13, 2009 - 10:14 PM
Jamchell
Joined Aug 24, '09
From San Diego, Ca
QUOTE (SwissFerdi @ Sep 13, 2009 - 9:37 PM) *
The 2GR-FE is a 3.5 L (3456 cc) version. Bore remains at 94 mm but stroke is reduced to 83 mm. Reported output varies depending on the vehicle application, but is approximately 268 hp (200 kW) at 6200 rpm with 248 lb·ft (336 N·m) of torque at 4700 rpm on 87 octane (R+M/2). This version features Toyota's Dual VVT-i, variable valve timing on both the intake and exhaust cams. Valves are driven by roller-follower rocker arms with low friction roller bearings, and a unique, concave cam lobe design to increase valve lift over the traditional shimless lifter type system of the 1GR-FE. This increases overall cylinder head height to accommodate the slightly taller roller rocker system. Moreover, the cylinder head is segmented into 3 parts: valve cover, camshaft sub-assembly housing, and cylinder head sub-assembly. As such, this valvetrain is used across all other GR engines with Dual VVT-i. Its service weight is 163kg.
Applications:
2005 Toyota Avalon (GSX30)
2006 Toyota Aurion (GSV40)
2007 TRD Aurion (Eaton Twin-Vortices TRD supercharger)
2006 Toyota RAV4 (GSA33/38)
2006 Toyota Estima (GSR50/55)
2006 Toyota Previa (GSR50)
2006 Toyota Tarago (GSR50)
2007 Toyota Camry (GSV40)
2007 Toyota Sienna (GSL20/23/25)
2007 Lexus ES 350 (GSV40)
2007 Lexus RX 350 (GSU30/35)
2007 Toyota Harrier (GSU30/31/35/36)
2007 Toyota Vanguard (GSA33)
2009 Lexus RX 350 (GGL10/15/16)
2007 Toyota Kluger (GSU40/45)
2007 Toyota Blade (GRE156)
2007 Toyota Mark X Zio (GGA10)
2008 Toyota Alphard (GGH20/25)
2008 Toyota Vellfire (GGH20/25)
2008 Toyota Highlander (GSU40/45)
2009 Toyota Venza (GGV10/15)
2009 Lotus Evora (280ps & 350Nm using Lotus engine management, Sport Pack package redline increased to 7000rpm)
Wikipedia is your friend!
Might be kind of steep in price though
post Sep 13, 2009 - 11:03 PM
Well this has been a very interesting thread, it seems like both are good choices. Trying to steer away from the turbo for now. Thanks for all the participation. 2GR-FE sounds like fun, in a couple of years
I have made my mind, and i want both. however i can only start with one. Down the road may look at the other one.
200HP is fine for me now. And the process has just begun!!!!!
post Sep 13, 2009 - 11:14 PM
SlvrCelica09
Joined Jan 10, '09
From Burtonsville, Maryland
good luck
This post has been edited by SlvrCelica09: Sep 13, 2009 - 11:43 PM
THIS IS WHERE WE HOLD THEM!
Still trying to find the cure for ST205 asthma..
6gc.net's outlaw vigilante because im a LEADER not a follower.
post Sep 14, 2009 - 12:18 AM
RavenAegis45
Joined Jun 25, '08
From CA
well everyones adding there 2 cents so i'll just add mine as well. the Beams does have alot going for it being a 3S-GE it does have aftermarket support no doubt about that plus most people just love the High RPMs it can reach which make it an awesome engine for the track. But of course it lacks torque in the lower Revs however since it has VVT-i it's not as bad as older versions of the 3S-GE. the VZ series is usually older and has a Cast Iron block which can withstand high PSi if you ever plan on boosting it especially if you get the latest versions, but there not as common as they are over sea's. the MZ series is a good engine to go with also since it's all Aluminum which is light and later models have VVT-i and make pretty good power numbers an yes they have alot more torque than 4 cylinders. Plus there incredibly common engines in the US. But IMO i would get the early VVT-i MZ versions found is some lexus models that have Duel throttle Bodies with Aluminum Intake Manifolds over the single throttle bodied ABS Manifolds of newer versions. ofcourse you can always swap those manifolds over to newer models... At least I think you can. Well thats my 2 cents hope it helped.
post Sep 14, 2009 - 2:58 AM
Edophus
Joined Apr 20, '06
thanks chaps i just try and remain balanced!, ah yeah i'm forgetting about the e153 smile.gif, i sometimes feel the s54 doesnt let you take advantage of all that torque. I think also the v6 for sure can be good for racing, i do know of some really powerfull fully built ones used for endurance racing, which is why i say if your not opening the engine up its probably more dependant on what you intend to do with it as to which is best, however if you intend to do a full on engine build, then its hard to see past the extra capacity of the v6.
mmm i love the 2gr-fe, i'm putting a blacktop beams in my gen 3 celica, as much because its rwd configuration makes it easier to install in the gen 3 as anything else, but i think when the time comes for more power, i wont be tuning the beams but will step up to the 2gr-fe biggrin.gif hopefully by then they will be easier to get and cheaper too.
bonzai - the stock weight of the ss3 beams is 1210kg, the superstrut setup adds a bit of weight to the front so a mac strut celica with a beams would be around 1190-1200ish so yeah your about right i'd say.
This post has been edited by Edophus: Sep 14, 2009 - 4:34 AM
post Sep 14, 2009 - 6:29 AM
K-ESD
Joined May 5, '05
for more on the 2GRFE
visit this link http://www.mr2oc.com/showthread.php?t=332390
it is the mainstream swap of the future for all toyotas that it fits. Can't wait to see someone try it in a 6GC.
and the question remains, does it bolt up to a AWD GT4 trans? if a header can fit behind the intermediate shaft and the block, there has to be room for the center dif of the GT4. I know I can barely squeeze my hand behind the shaft and block on my 3MZ and there's only aprox 10mm that doesn't clear for the center dif.
sorry for going a little off topic
post Sep 14, 2009 - 6:58 AM
Edophus
Joined Apr 20, '06
QUOTE (K-ESD @ Sep 14, 2009 - 7:29 AM) *
completely agree, in my eyes the 2gr-fe has pretty much rendered the beams/vz/mz and even the 1uz v8 engines redundant, or at least it will do once there a bit easier and cheaper to get smile.gif the dual vvti and true dohc will make these engines very tunable aswell so i suspect the stock power is a lot less than there true potential.
2 Pages V  < 1 2
Lo-Fi Version Time is now: January 16th, 2025 - 12:43 AM
