> Low RPM Sputtering
post Sep 9, 2009 - 12:00 PM
bojangles_8686
Joined Nov 12, '02
From Baltimore, MD
At idle, RPMs drop down to around 500 then come back to normal. It is a really quick and inconsistent drop. It keeps dropping until I hit ~30 mph, then the drop disappears. I have replaced the plugs and cleaned the AIC. Not too sure what to start checking on this one, help me out fellas.
post Sep 9, 2009 - 1:23 PM
2bcelica
Joined Mar 22, '07
From Murphy, TX
QUOTE (bojangles_8686 @ Sep 9, 2009 - 6:00 PM) *
there are alot of issues that can affect idling issues - mine was because of an air leak at the intake manifold. throttle body might need cleaning - AFM/MAF sesor might need to be replaced. U coud try some fuel injector cleaner
This post has been edited by 2bcelica: Sep 9, 2009 - 1:25 PM
post Sep 9, 2009 - 1:29 PM
bojangles_8686
Joined Nov 12, '02
From Baltimore, MD
Thanks for the response. I tried injector cleaner when the problem started and nothing changed. Ill check out the sensor when I get off work and give an update later tonight.
post Sep 9, 2009 - 1:32 PM
samir0189
Joined Mar 8, '08
From Orlando, Florida
I had a "similar" problem, i had low rpm sputtering on throttle, and nothing while cruising, turned out to be my wires or my fuel filter i think... try a whole tune up. you said you did plugs, do wires, and the fuel filter, and if the problem persists you can rule those out. wink.gif
My F/S Thread!
Ferdi says (11:29)
post Sep 9, 2009 - 1:53 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
yes, replace:
plugs (check gap)
Wires
Dizzy Cap & Rotor
PCV Valve
Air Filter
Fuel Filter
post Sep 17, 2009 - 1:36 AM
eduxz
Joined Jul 7, '08
From Hallandale Beach
i had a similar issue i took to the shop and the mechanic started messing with the distributor he keep turning it clockwise/counterclock wise until it reached the desired rpm. Another thing he also looked at was at the throttle wires. He told me they were loose so he made them more short
Lo-Fi Version Time is now: January 13th, 2025 - 6:41 AM
