> 95 celica high idle, i have a 95 celica with spiradic idle
post Sep 9, 2009 - 10:54 PM
Celica_Rob
Joined Sep 9, '09
From texas
My 95 celica has a k2n filter and and airbox elim tube to intake, im getting a adle at about 1800 -1200 depends on heat i guess,some times it just all the sudden runs perfect then will click and idle high again,when the idle is correct the car drives perfect, when high idling it jerks when you let off the gas and hit again, sometimes it has a slight miss then when you give it gas it goes away.When you start it it stumbles until you rev it up a few times kinda like its running rich, then raises idle,there are no check engine lights on and dont know about any engine swaps.please help its making me mad, car is quick when runs right. thanks robert
post Sep 13, 2009 - 11:55 PM
Pipelinepro45
Joined Sep 13, '09
From Virginia
hey man i had the same problem...ended up being depris from my intake in my throttle body...take off the intake and check it with a flashlight and see whats up. other than that check you idle air control sensor...sometimes they go bad and the check engine light still wont come on....or check your idle control switch and turn down your idling...that could be a temp fix
post Sep 14, 2009 - 12:50 AM
Celica_Rob
Joined Sep 9, '09
From texas
QUOTE (Pipelinepro45 @ Sep 13, 2009 - 11:55 PM) *
Lo-Fi Version Time is now: January 15th, 2025 - 7:04 PM
