Installing KYB Inserts, Fluid inside front strut??? |
Sep 15, 2009 - 9:50 PM |
Enthusiast Joined Apr 24, '04 From S. Cali Currently Offline Reputation: 0 (0%) |
I've pretty much got all of it down, but i've heard about some kind of liquid inside the front tube...what exactly is the liquid and what should i replace it with should i spill it or something?
Sep 15, 2009 - 11:53 PM |
Enthusiast Joined Nov 21, '05 From Tacoma, WA Currently Offline Reputation: 7 (100%) |
You shouldn't have liquid to worry about. The cartridge should be sealed.
Although if you feel that you must replace any water that's gotten between the cartridge and the carrier make sure you replace it with deionized water. It won't rust the metal as badly as tap or saltwater will. |
Sep 16, 2009 - 12:28 AM |
Enthusiast Joined Sep 8, '09 From australia, east coast Currently Offline Reputation: 0 (0%) |
i put a kyb insert into my 5th gen.....
if the liquid u are talking abount is the shock fluid..... then just tip it into a container..... clean and slip insert in tighten up top and put spring back on....... -------------------- st184 3vz-fe convesrion complete
st185 AWD 3vzfe turbo conversion in progress and stock st204 daily.... |
Sep 16, 2009 - 3:16 AM |
The cartridges are sealed, but the struts are filled with a very thin oil -- for heat dispersion. Air is not a good conductor. The oil transfers heat away from the actual shock (the cartridge in rebuildable struts), improving function and prolonging life.
KYB recommends simply capturing the oil from your struts and re-using it, so be careful when taking the gland nut off, and of course use a very clean container to collect it. Keep in mind the oil's not there for lubrication so viscosity isn't the issue and it hasn't been subjected to the kind of use which breaks down engine oil. And as a side note, do not use engine oil as a replacement. Motorcycle fork fluid will do, but it'd cost dearly. |
Sep 16, 2009 - 10:13 AM |
Wouldn't some sort of heat conducting grease work best? When I took mine apart I didn't find any fluid. Maybe it had all leaked out.
Sep 16, 2009 - 12:42 PM |
Enthusiast Joined Feb 15, '08 From Royal Oak, MI Currently Offline Reputation: 7 (100%) |
-------------------- God made man....
Everything else... Made in China |
Sep 16, 2009 - 1:18 PM |
Enthusiast Joined May 3, '09 From jacksonville/flemming island florida Currently Offline Reputation: 1 (100%) |
use brake fluid
-------------------- 94 stx coupe, super mario kart beater
87 toyota 2wd truck, rebuilding engine 85 celica gt-s project |
Sep 16, 2009 - 2:52 PM |
Never put anything. Thats what kyb recommends
http://kyb.com/service/installationtips/in...lationtip08.php -------------------- God made man....
Sep 16, 2009 - 6:17 PM |
ha too late, i put a little bit of used motor oil when i did put blisten inserts.
Sep 16, 2009 - 8:15 PM |
ha too late, i put a little bit of used motor oil when i did put blisten inserts. ya, i saw it on youtube on blistein inserts, they put oil on it but im not sure if thats manufacturer recommended. -------------------- God made man....
Lo-Fi Version | Time is now: January 11th, 2025 - 8:08 AM |
