> ST Celica 1.8L - header advice, Headers on ebay
post Sep 16, 2009 - 8:42 PM
mentat
Joined Apr 25, '05
From Canada
ebay header 1
header2
http://cgi.ebay.com/ebaymotors/Celica-94-9...sQ5fAccessories
are these ok , any suggestions? Im just trying to patch the car up not worried about performance really. $45 seems cheap though
post Sep 16, 2009 - 8:46 PM
johnnehh
Joined Aug 5, '09
From Oakley, CA
I'm not sure about the ST header, but I put a header on my car and it made a world of difference. You can definitely feel more power being there. Just wait for the guys that know all of the car lingo to get on this thread and they'll tell ya which one to get wink.gif
1996 Toyota Celica GT (GT4 conversion) - SOLD :(
2002 Audi A4 1.8T Quattro - Daily Driver
post Sep 17, 2009 - 11:21 AM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
search button is your friend, located on the top right hand corner...
http://www.6gc.net/forums/index.php?showto...28&hl=raspy
post Sep 17, 2009 - 11:55 AM
nik
Joined Sep 30, '02
the ST uses 2 o2 sensors all those headers only have one so youll have to have another one welded on
post Sep 17, 2009 - 12:03 PM
rave2n
Joined May 29, '09
From Gainesville, FL
Where is the second one located? Obviouslly the first one is right on the base of the header. Which can be seen easily.
I've heard Surewinproducts are the best headers...
This post has been edited by rave2n: Sep 17, 2009 - 12:04 PM
post Sep 17, 2009 - 3:00 PM
mentat
Joined Apr 25, '05
From Canada
good info thanks.
I found that post but the item has been taken off ebay.
To bad it needs to be welded..
post Sep 17, 2009 - 3:10 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
i ran mine without hooking up the 2nd O2 sensor. ran with no problems
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Sep 17, 2009 - 3:40 PM
benzo
Joined Jul 23, '09
From Fresno, Ca
QUOTE (Smaay @ Sep 17, 2009 - 3:10 PM) *
hey when you did that did you get an check engine light problems? im very close to ordering my header, but i want to make sure i get the right one.
post Sep 17, 2009 - 7:52 PM
BonzaiCelica
Joined Apr 24, '08
you have to weld a bung in the middle of the midpipe. THey will burn a hole thru the midpipe and attach a bung so that you can screw and unscrew the o2 sensor whenever you want. if you dont plug in 2nd sensor you will see the cel.
post Sep 22, 2009 - 11:07 AM
nik
Joined Sep 30, '02
post Sep 22, 2009 - 1:51 PM
legalkid86
Joined Dec 14, '08
From RGV, Texas
well i got the one from tuning pros and too be honest we had problems fitting it on, they drilled the holes to low, so i had to modify it at the shop, i sorta regret getting the one from tuning pros cause now i have a leak in the headers....id go with the most expensive one and get some header wrap
wAkE uP, u'Ll sLeEp WhEn U DiE.....
post Sep 22, 2009 - 7:05 PM
BonzaiCelica
Joined Apr 24, '08
there are all made the same, or atleast i think. only mod i had to do was drill the holes with dremel tool to make them bigger so that the header would attach to the engine. make sure you flanges are flat or you will get an exhaust leak. if you need gasket material heres the link. i went to various exhaust shops and i could not find any. you have to make your own exhaust gasket
http://azcustomcars.com/product.php?productid=56790
This post has been edited by BonzaiCelica: Sep 22, 2009 - 7:05 PM
Lo-Fi Version Time is now: December 1st, 2024 - 8:39 PM
