8 Pages V  « < 2 3 4 5 6 > »
> I Swapped 3s-ge Redtop Into 97 Limited Edition Vert., Pictures are restored, many more added 5/24/11
post Jan 2, 2010 - 10:31 PM
D-Man
Joined Jan 18, '08
From Houston
bad harness, call Dr. Tweak!!
Damn D-Man - most impressive.
post Jan 3, 2010 - 10:19 AM
QUOTE (freddy121389 @ Jan 2, 2010 - 6:39 PM) *
i was looking at the very exhaust on there, it was cheap to begin with, what deal did he cut you on top of that?
i have bought like 4 times from him, so i asked him to let go of the exhaust as he did not use it.
post Jan 10, 2010 - 9:10 PM
update !
post Jan 11, 2010 - 4:09 PM
small one, engine is not out yet, but is ready, need to disconnect the ps, a/c and harness from cabin.
Only work like 2 hours a day not every day due to my work. I work 12 hour shifts so need to rest.
i have taken pics, but will wait to post them.
slowly getting there, of course this is a one man job, lol...
post Jan 11, 2010 - 11:36 PM
Rusty
Joined Nov 5, '07
From New Zealand
sweet best of luck during swap, but remember to be careful etc, since your working alone.
post Jan 12, 2010 - 1:58 AM
yup, curious thing, is that there is a noticeable difference in axles, i may keep a hybrid setup, using what i have from the swap, and completing the axle with mine, ill post a pic in the moring to show the difference, my axles are wimpy anyway, and least the first portion can still be JDM.. lol,
yes im being careful.. thanks... is a new experience.
post Jan 20, 2010 - 12:14 PM
the only thing keeping the engine is the side mounts lol,
Im a noob, i messed up the core heater of the a/c so i guess i have to get a new one, and put it in while im at it...
I spilled the fuc....oil last night, the rear mount heard so many new names thumbsdown.gif , and i used gojo as bodywash. But all is good, still on the way.
Boy, never thought it was going to be so fun cwm13.gif , the engine is coming out tonight.... thumbsup.gif
if the beams works i may start posting some things for sale. Not now.
just as a peek... but not now, lol
starting to tear down the engine.
This post has been edited by njccmd2002: May 26, 2011 - 1:27 AM
post Jan 20, 2010 - 11:47 PM
pain in the arse to get it from the top, specially if on jackstands on a high level....
so far, possible a/c lines damage and the a/c heater core is damaged.. lol, the experience is priceless...
the pics show the carnage
recycling the power steering fluid!!!
my filter and the maf adapter, that i will use...
This post has been edited by njccmd2002: May 26, 2011 - 1:34 AM
post Jan 20, 2010 - 11:55 PM
Many kudos to you for doing this yourself...seriously. Quite ballsy. Can't wait to see the finished product, obviously.
post Jan 20, 2010 - 11:58 PM
CelicaST_CALI
Joined Feb 28, '07
BANNED. for life, you moron.
post Jan 21, 2010 - 12:19 AM
the heater core pipe, did you crack it ? You should of just disconnected it from the water line on the motor frown.gif get in there and try to make that round again, or else it will leak forever (very bad). When you eventually put a new hose/clamp on it just make sure it's tight and look for leaks after...
The A/C line is just dented right ? no problems unless it's cracked.
ya ! motor's out ! change your fuel filter with an OEM one !
post Jan 21, 2010 - 1:29 AM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
nice progress
This post has been edited by BonzaiCelica: Jan 22, 2010 - 11:29 PM
post Jan 21, 2010 - 4:48 AM
Rusty
Joined Nov 5, '07
From New Zealand
Oohh stink about the hoses, but big congrates there, you have the engine out thumbsup.gif
yeah replace the fuel filter, fix up those lines and time to give the engine bay a tidy up, since the motor is out.
post Jan 21, 2010 - 9:19 AM
i dont think the a/c lines are cracked, but i hate to try to fix the heater core and still leak, once im at it might as well get a new one. Especially if its getting ready to crack on the inside.
Now that i see it, not as easy to get the engine out. Im thinking to change the timing belt, the pulleys and waterpump now!
Dont want to do this again for this, if i can do it now. Ill keep posted.
post Jan 22, 2010 - 11:24 PM
erahman85
Joined Aug 29, '07
From San Diego
Awesome now were on the same boat lol!!!!!
post Jan 22, 2010 - 11:40 PM
97celiman
Joined May 22, '08
From dallas texas
not to threadjack but can someone explain this gojo as a bodywash phrase...
post Jan 23, 2010 - 2:32 PM
samir0189
Joined Mar 8, '08
From Orlando, Florida
QUOTE (97celiman @ Jan 23, 2010 - 12:40 AM) *
Gojo is a maker of heavy duty hand degreaser, the stuff you use after doing work on the car to wash the "blackness" off your hands, like LAVA soap, GOOP, etc, you've had to use one of them.. ...
He had to use it as a bodywash cause he was entirely coated in grease/oil/soot. laugh.gif
My F/S Thread!
Ferdi says (11:29)
post Jan 28, 2010 - 3:45 PM
finishing the harness from the beams, i have noticed the subtle differences...
the srs plug i think it goes to pin 4 and not 5 in the light grey and the white plug in the usdm has way more wires goin to it and so is the dark pin ON THE BEAMS... SO MANY WIRES.....
USDM HARNESS
BEAMS HARNESS this is where you have to do the repining of the clutch start, and where the srs wires come to...
This post has been edited by njccmd2002: May 26, 2011 - 1:37 AM
post Jan 28, 2010 - 5:22 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
best active thread on the board now, nice work & keep it up!
post Jan 28, 2010 - 6:09 PM
The USDM white plug has a brown, white and brown wire that im trying to identify? what were those...
The beams dark grey plug has a yellow, brown, gray and white/blue wire that are extra and missing the blue/white..
My car has cruise, and maybe this beams had abs, or any other sensor, i would like to find out if these are important....
Been browsing the electrical manuals and its tedious..
Lo-Fi Version Time is now: November 23rd, 2024 - 12:55 PM
