3 Pages V   1 2 3 >
> 7g seats, bought 7g seats tryin to install
post Sep 20, 2009 - 3:39 PM
wyzzardcelica
Joined Mar 14, '09
From Omaha, NE
anybody know if there's a way to put the 7g leather seats into my 97? i bought them on a whim and obviously they are not going to fit, anyone kno if theres someone out there who has done this successfully? thanks.
post Sep 20, 2009 - 4:27 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
Try using the wonderful search function we have on this site.
http://www.celica-club.co.uk/wiki/index.ph..._seats_in_Gen_6
http://www.6gc.net/forums/index.php?showto...l=7th+gen+seats
Just some links I found after a quick 30 second search.
**** Photobucket
post Sep 20, 2009 - 6:53 PM
AMCMoe
Joined Nov 20, '04
From Carlisle, PA
You can, but you don't need to do any welding. Swap the metal bracket under the 6th gen seat onto the 7th gen seat and then use the 6th gen rails. Easier said than done but it's not hard at all...
post Sep 23, 2009 - 2:25 PM
wyzzardcelica
Joined Mar 14, '09
From Omaha, NE
i'll give it a shot thnx guys
post Sep 23, 2009 - 4:39 PM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
those seats weigh the same as our stock ones right??
post Sep 23, 2009 - 9:34 PM
AMCMoe
Joined Nov 20, '04
From Carlisle, PA
I didn't notice much difference. Probably within a few lbs of each other.
post Sep 27, 2009 - 2:18 AM
sunwukongg
Joined Mar 10, '08
From Socal, OC
dang..7g seats look sweet
post Sep 29, 2009 - 12:15 AM
6strngs
Joined May 12, '06
From Wilmington, NC
the seats in my 7g have airbags in the sides, which I'm sure would make them heavier than stock 6gc seats, the non-airbag ones are probably about the same weight
post Oct 1, 2009 - 2:49 PM
nics
Joined Feb 15, '08
From Royal Oak, MI
QUOTE (AMCMoe @ Sep 20, 2009 - 4:53 PM) *
Cant find swap info without welding. A write up from you would be great but you've done it already and missed taking pix.
God made man....
Everything else...
Made in China
post Oct 2, 2009 - 4:10 PM
AMCMoe
Joined Nov 20, '04
From Carlisle, PA
I was originally going to take pictures but it's really not hard so I didn't bother making a write up. Here's the general idea of what you have to do-
Remove the 6g seats from the car. Get a flat head screw driver and start by removing the plastics coverings on each side of the seat. Here is where all the mounting tabs are-
To get the height-adjustment knob off, take a rag and pull it across the c-clip to remove it. (You can see it in the picture) Or a flathead screw driver works too.
Then remove the brackets from the seat- 4 bolts on the bottom, and there are maybe 2 on each side of the back cushion. Once the bolts are out the seat should more or less come apart from the bracket.
There is a bar that runs through the bottom of the back-cushion for the 'reclining' function. This is the hardest part (you'll see) of the whole swap when you're putting it back together.
Once you have the cushions and brackets removed, start by removing the metal support from the bottom of the seat. There are hog-ties and a plastic 'rail' they you need to remove.
Once they're removed, the metal support piece will come away from the cushion. You need to swap this piece from the 6g cushion to the 7g cushion. The bottom cushion of the two seats is identical, but the "metal support piece" has the two front holes in a different place, that is why you need to swap it from the old 6g seat to the 7g seat (so you can bolt the seat to the 6g brackets).
Once you have that swapped, you can start putting the seat back together. The bar that runs through the bottom of the back-cushion can be tricky to put in without the seat falling apart. It helps if you thread the bolts in just slightly to keep the cushion in place while you're aligning that bar. (you'll see what I'm talking about when you go to do it)
Once the bar is back in, tighten the 8 seat bracket bolts and test the reclining function to make sure you got the bar in there correctly. If it works, you're ready to start on the other front seat. smile.gif
Hope these instructions help. Post back if you need any help.
post Oct 3, 2009 - 6:37 AM
TiGZ461
Joined Aug 6, '09
From Bergen County,NJ
Good post man seems way easier then welding.
all you needa to now, is come to jersey and drop those seat at my house tongue.gif
1996 Toyota Celica ST 25th Anni. Edition #461
post Oct 5, 2009 - 3:03 PM
nics
Joined Feb 15, '08
From Royal Oak, MI
cool! nice info! will try 'em soon! still looking for a 7gc cloth seats
God made man....
Everything else...
Made in China
post Nov 25, 2010 - 9:28 PM
jcbass7
Joined Apr 20, '06
From Florida
So I am in the middle of this project myself, with the seats apart in front of me. Can anyone confirm that the picture he has up of the bottom of the 6g seat is in fact the newer style 6g seat that wasn't the same as the 94 ones? I am running into a much different looking seat bottom and it is keeping me from getting these swapped over. I'm about to try welding this up instead..
This post has been edited by jcbass7: Nov 25, 2010 - 11:04 PM
post Nov 25, 2010 - 9:33 PM
block
Joined Jul 27, '06
From Soda
if it works, this should be stickied. a lot of people want to do this. im looking into doing this with the 7g cloth seats.
post Nov 26, 2010 - 12:11 AM
jcbass7
Joined Apr 20, '06
From Florida
7th gen seat pan (2000)
6th gen seat pan (1994)
This post has been edited by jcbass7: Nov 26, 2010 - 12:14 AM
post Nov 26, 2010 - 2:42 PM
6th gen pan 1995
post Dec 9, 2010 - 8:11 PM
hokuten3
Joined May 30, '10
From PA
When you get to the part putting the seat back together, the back of the seat doesn't have any place to screw it in since we are using the 6g brackets. so what do you do there?
QUOTE (AMCMoe @ Oct 2, 2009 - 4:10 PM) *
...5sFREAK...
post Dec 9, 2010 - 8:24 PM
jcbass7
Joined Apr 20, '06
From Florida
I used the 6th gen plastics as well and it all worked perfect. in the car now..
post Dec 9, 2010 - 8:53 PM
hokuten3
Joined May 30, '10
From PA
how did you put your seat back together?
...5sFREAK...
post Dec 9, 2010 - 8:58 PM
jcbass7
Joined Apr 20, '06
From Florida
QUOTE (hokuten3 @ Dec 9, 2010 - 8:53 PM) *
sorry i read your post wrong, I used the 6th gen rails and seat bottom complete assembly and swapped the foam and leather seat cover from the 7th gen. The seat backs for the 7th gen and 6th gen bolt in exactly the same with two bolts and a solid steel bar that runs across. the steel bar fits into a small notch on each side. I can try to get pictures later.
so theoretically if you wanted 7th gen seats you could just swap the back of the seat over and keep your 6th gen bottoms (which have a bit more support on the sides..)
This post has been edited by jcbass7: Dec 9, 2010 - 8:59 PM
3 Pages V   1 2 3 >
Lo-Fi Version Time is now: December 4th, 2024 - 6:28 AM
