3 Pages V  < 1 2 3
> 7g seats, bought 7g seats tryin to install
post Dec 14, 2010 - 12:51 PM
zoik
Joined Aug 28, '07
From france
hum, one question, is ti possible to remove airbag system from the 7gen seats who have them without having a awfull result?
post Dec 14, 2010 - 11:46 PM
AMCMoe
Joined Nov 20, '04
From Carlisle, PA
QUOTE (chacha @ Dec 14, 2010 - 1:12 AM) *
thanks for all your help folks....this is a much easier thread to do the swap for....i haven't tried figuring out what i want to do, but if i can't use the plastics that comes with the 7gc and my 6gc plastics are busted...i think i might just go the welding route...i remember reading only three of the holes on the 7gc bracket work...but ill see what i have to do to make the fourth fit after the seats are cleaned.
3 holes for what? I think I have some spare charcoal colored 6th gen seat plastics...I'll have to check. If so, you can have them. Compare your 7th gen plastics to the pic I posted on the first page of the 6th gen plastics. It's been so long ago that I can't remember anymore, but I THINK I did use the 7th gen plastics when I swapped the seats into the car. I know I have a set of 7th gen plastics in my basement, and should have a spare set of 6th gen platics, I'll have to compare them to see where the mounting points are since I don't have my 7th gen seats anymore.
One slight difference with the 7th gen seat bottom is that the height adjustor is in a slightly different spot, about an inch away from the 6th gen location IIRC. Not a big deal but if your 7th gen seat cushion is well used, the dye may be slightly worn in a ring around where the old knob location was and where the new one is. Very unnoticeable unless you're looking for it, but it is there.
@zoik. Disconnect the battery from the 7th gen, wait for a few minutes, and then remove the airbags in the seat.
post Dec 15, 2010 - 12:41 AM
chacha
Joined Dec 29, '05
From So-Cal
sorry, i meant i read a forum stating only 3 of the 4 mounting holes of the 7gc seat bracket(whole rail assembly) fits the 6gc holes on the floor....
one last thing....were you able to still use the 7gc seat sliders? i really like the fact that the handle to slide the seats is all-around in comparison to the 6gc which has a small handle on the corner of the seat to lift up for adjustment (sliding effect)?
This post has been edited by chacha: Dec 15, 2010 - 12:49 AM
post Dec 15, 2010 - 10:49 AM
zoik
Joined Aug 28, '07
From france
QUOTE (AMCMoe @ Dec 14, 2010 - 11:46 PM) *
thanks, but i meant removing the plastic cover on the exterior, not only the explosive for the airbags
post Dec 19, 2010 - 9:17 PM
chacha
Joined Dec 29, '05
From So-Cal
started to remove and i think i will weld instead. replacing the metal support pan with the 7gc cushion was hard because it doesn't completely cover the foam...i am afraid of messing of the fabric just in case the sharp edges cuts and tears the cloth.
post Dec 20, 2010 - 12:24 PM
AMCMoe
Joined Nov 20, '04
From Carlisle, PA
They're identical in size, only difference is the bolt hole locations. Are you sure you even got 7th gen seats?
post Dec 20, 2010 - 2:01 PM
chacha
Joined Dec 29, '05
From So-Cal
2003...my 94 metal pan didn't fit right.
post Dec 22, 2010 - 10:20 PM
94s wont work. its only 95 and up. sorry
post Dec 23, 2010 - 3:10 AM
chacha
Joined Dec 29, '05
From So-Cal
thanks for the clear up....guess im gonna have to weld
post Jan 7, 2011 - 12:19 AM
Ted95
Joined Mar 8, '09
From Westport, MA
QUOTE (jcbass7 @ Dec 13, 2010 - 7:07 PM) *
QUOTE (Ted95 @ Dec 13, 2010 - 12:04 PM) *
so as long as you have 95 seat rails and stuff you can just take the cushion of the 7g and bolt them to the 6g hardware?
you actually take the foam cushion off of the metal seat pan and put it onto the metal seat pan of the 6th gen set. It clips right on and then a few zipties and its good to go.. Like I've said, you can just keep the 6th gen bottom cushion if you like it better. Just swap over the seat back and your done.
that sounds easy enough. i want to do it in the furture, but i want to find clothe seats instead. all the junked 7gens around here are all leather so far kindasad.gif
st205 powered ss3 coupe
post Jul 19, 2015 - 10:33 PM
doory100
Joined Jun 21, '14
From Ottawa, Ontario, Canada
QUOTE (Ted95 @ Dec 13, 2010 - 1:04 PM) *
Are you sure they are not 96 and newer because my 95 does not have the 4 bolts on the under side of the seat cushion. They seam to be spot welded? do you know what i mean? Also the handle to move the seat back and forth is just a handle bar and does not go the entire length of the seat like the gen 7 adjustment bar does.
3 Pages V  < 1 2 3
Lo-Fi Version Time is now: November 27th, 2024 - 1:08 PM
