Turbo help and questions, Noob needs help restoring turbo celica |
Sep 22, 2009 - 12:08 PM |
Enthusiast Joined Sep 11, '09 From NYC Currently Offline Reputation: 2 (100%) |
Hi, I am trying to piece this turbo celica back together and I have some questions. I am new to celicas and everything.
First is this sensor, I have a picture of it from my car but it's not the best, I will try to get a better pic of it. I just want to know what sensor that is(MAP?) and how to mount it onto the IC/intake pipes. In this picture it's the sensor right next the coupling between the intake and the BOV pipe. I also want to know how easy it is to weld a 1G DSM BOV onto the piping I am using. I bought the whole BOV with the stock piping, but the piping is way too small to work with. What are other ways to make this work? I can't seem to find the right coupling size to fit this to my IC piping. I have other problems with leaking oil, but I am in the process of getting the oil feed fitting by mail and waiting to install it. Thanks Batman for the hookup. I will probably be using this posting for any other questions or problems I run into later down the road of getting this car back to running good. BTW, this was owned by a past member from this site, which I recently found out. His name was Shin on the boards..just a little FYI..haha. This post has been edited by ravinaziankid: Oct 4, 2009 - 6:30 PM |
Sep 22, 2009 - 2:02 PM |
Didn't JDM guy turbo Shin's car?
I would ask Defgeph, Batman, or Presure2 (probably Presure2, as they're running a 5sfte setup as well) IIRC, that is your IAT sensor. This post has been edited by 95CelicaST: Sep 22, 2009 - 2:04 PM -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
Sep 24, 2009 - 2:44 AM |
Air temp sensor for the intake, this belongs in the air box.
I've seen someone post that on a 5s-fte it should be in the boosted pipes (between IC and TB) and on the 3s-gte it should be in the vacuum pipes (between turbo inlet and air filter). Personally I fail to see how a boost tight seal can be achieved like that, but you need to make a 20mm hole and get ahold of the grommet from the airbox. -------------------- Mike W
Sep 24, 2009 - 9:21 AM |
Oh so that's the IAT sensor..I was thinking of using a rubber piece to make sure it fits good and doesn't fall out.
Also, has anyone used the 1G eclipse turbo BOV? Is it better to get the flange cut and welded onto the IC piping or use couplings? The thing is that the BOV pipe that it came with is very small and hard to find the right size from the BOV to my 2.5' pipes. |
Sep 29, 2009 - 1:32 PM |
Well I got the new turbo in..the old turbo was pretty much worthless, the nut in the middle was missing and the blades were all destroyed. Lots of shaft play and movement.
While installing the turbo I ran into a problem. I was trying to screw the T fitting in for the oil feed line with the stock oil pressure sensor on the fitting. While doing this, the sensor's wires snapped and looks very short, a little too short to solder and rewire. Anyone have any ideas? I will try to get pics, but it's that sensor that normally goes into the block. Anyone have an extra that they can sell me or just the wiring part of it? Also, I am still deciding what to do about the BOV. Would it be better to have the BOV cut from the stock piping it came with and then welded onto the 2.5" piping I'm using now? Because right now, I am setting it up by using reducer couplings, 2"-2.5" using the screw on metal straps that normally come with intakes. The BOV pipe is 1.75" and seems like it throw the flow off since it's going from a 2.5" to a 1.75" pipe. Please give me some ideas, I am just open to any ideas but also want to stay economical which is why I got the DSM BOV. I will get some pics up soon, not much to see. This post has been edited by ravinaziankid: Sep 29, 2009 - 1:47 PM |
Oct 4, 2009 - 6:29 PM |
Update again.
I am leaking oil from where the oil filter is originally supposed to be. Does anyone know what can cause this? Can it be cracked or the gasket or something leaking? I haven't had the chance to take it apart so I don't know how it's held together from the oil relocation kit to the block. Any help would be great. |
Oct 19, 2009 - 11:58 AM |
OK, got the car running and boosting, just needs a tune and some gauges installed. I just need to know what the stock injector size are for the 5sfe or how to tune using the SAFC2. Also, when installing the wideband, which 02 section should I install it in? Is there one after downpipe?
Does anyone have a basic setup for their SAFC2 that I can run first and then go from there? That would help a lot. |
Oct 19, 2009 - 4:24 PM |
Enthusiast Joined Jul 22, '06 From San Antonio / georgetown, Texas Currently Offline Reputation: 9 (100%) |
OK, got the car running and boosting, just needs a tune and some gauges installed. I just need to know what the stock injector size are for the 5sfe or how to tune using the SAFC2. Also, when installing the wideband, which 02 section should I install it in? Is there one after downpipe? Does anyone have a basic setup for their SAFC2 that I can run first and then go from there? That would help a lot. http://www.6gc.net/forums/index.php?showto...hl=afc+settings some basic settings to start from. just be sure to tweak them to your engines needs -------------------- |
Lo-Fi Version | Time is now: November 25th, 2024 - 6:41 AM |
