![]() Enthusiast ![]() Joined Aug 29, '09 From Ottawa, ON, Canada Currently Offline Reputation: 1 (100%) ![]() |
I need the interior fuse box cover:
![]() A storage box cover: ![]() The entire power antenna assembly (I have no idea what is wrong with mine, but it never goes down, and I can't hear the motor running either when I turn the radio on and off). I will also consider a shorter antenna or a hidden antenna. And I need a rear-view mirror. I tried to take mine off, and I accidentally unscrewed the single philips screw too far, so the entire assembly fell apart into the mirror casing. I cannot open the casing since it is all one piece. So now the mirror holds on, but not tightly, so it wobbles. PM me prices, shipped to Ottawa, Canada. Thanks in advance. |
![]() Enthusiast ![]() ![]() ![]() Joined May 15, '09 From yonkers, NY Currently Offline Reputation: 8 (100%) ![]() |
u can remove the mirror i know cuz i did that aswell its a bit ch but u can put it back 2gether. the mirror it self can be remoed if u have a small flat head.
-------------------- *Thing i want for my car(i wish i had money)*
-light blue tint (next step will do this right after i get my paint job) WTB Reasonably priced Projectors just Lows |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Nov 7, '06 From Houston, Tx Currently Offline Reputation: 17 (100%) ![]() |
i think i have that fuse box cover, but I don't have that pocket anymore. some jacka$$ stole mine. If i can figure out how to take off the rear-view mirror, that'll be available as well.
-------------------- -Alex {](O_o)[}
1993.5 Toyota Supra ....with stuff.... ....sorta broken.... 1998 Toyota Celica ....this one, too, has stuff.... ....broken....yeah...definitely broken.... |
i think i have that fuse box cover, but I don't have that pocket anymore. some jacka$$ stole mine. If i can figure out how to take off the rear-view mirror, that'll be available as well. The rear-view mirror is easy to take off. Just spin it around, and find the one screw that's holding it on, and unscrew it. Do this slowly though, being extra careful not to let the screw come all the way off. You just want to unscrew it enough so that you call pull the mirror off of the thing that holds it to the car roof. If you unscrew it all the way, the assembly the holds the mirror in place falls apart inside the mirror casing, and it is almost impossible to reassemble. |
or u can unscrew it from the roof just 2 screws under a cover get the whole thing.
Lo-Fi Version | Time is now: February 20th, 2025 - 2:37 PM |
