Will a 3sgte head fit to a 5sfe |
Sep 23, 2009 - 4:58 PM |
Enthusiast Joined Sep 23, '09 From minnesota Currently Offline Reputation: 0 (0%) |
Hi every one im new here so need some adivce... i have a 94 celica gt and my head is nocking and i want to know if a 3sgte will fit on to it? i just want to get a little more power to the car.
Sep 23, 2009 - 5:10 PM |
Enthusiast Joined Apr 27, '09 From West Coast Canada Currently Offline Reputation: 0 (0%) |
your head is knocking? or your crank is knocking?
head would tick (valve tick) but not knock gen3 3s-ge/3s-gte head will fit gen2 3s-gte head will require some porting for coolant passages as well as drilling the head gasket |
Sep 23, 2009 - 6:34 PM |
sorry i mean the head is ticking.. how will you solve that or you think putting a new head on is better? what do you go recommand?
just asking is you do put a 3sgte head on is there an different in power? |
Sep 23, 2009 - 6:40 PM |
sorry i mean the head is ticking.. how will you solve that or you think putting a new head on is better? what do you go recommand? just asking is you do put a 3sgte head on is there an different in power? 3s-ge head*** yes, u may notice more top end as the GE performance head has a much higher redline. valve tick is due to build up in the head, clean it and replace valve seals. OR. new/used head but. swapping heads also requires you to use all the GE sensors and can get costly with harness modifications |
Sep 23, 2009 - 7:10 PM |
i guess if it get costly then might just swap it... hay thank for the adivce ill try to get it out and clean it for now.
Lo-Fi Version | Time is now: January 12th, 2025 - 2:05 PM |
